Old 04-29-2008, 10:01 PM   #1 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Ford Thunderbird
90 day: 27.75 mpg (US)
Freewheel Clutch: Lower RR
A cool technology of the 1950-60's national economy runs was the freewheel clutch.
The freewheel clutch was either attached to the transaxle or the wheel hub, only allowing power to be transmitted to the wheels in one direction. Like a ratchet, the wheels were driven when powered but freewheeled while gliding.
Most think of rolling resistance (RR) as being a quality of the tires and bearings, but it also encompasses friction from a spinning transmission and main clutch end. By using a freewheel clutch, you remove all the robbing friction from the axles inward.
The clutch seemed simple to design, just being a small freewheel hub you could probably pick up a McMaster-Carr spliced into an axle. You do lose reverse, but that's undesirable anyways...
- LostCause
Old 04-29-2008, 10:18 PM   #2 (permalink)
toomuch's Avatar
Unwaking Sleeper - '00 Toyota Corolla LE
90 day: 34.11 mpg (US)
- LostCause
This would not be as much of a problem on the jeep hurricane, that thing could spin and crab walk! Of course, dual engines is not really in the spirit of this forum
Was this technology ever used in production vehicles?
Old 04-29-2008, 11:03 PM   #3 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
I saw a few videos a while back about a Saab Sonnet that was converted to electric.
It seemed to have a really nice range to it. If it had freewheeling, that may have been part of why the range was so decent.
http://www.diyelectriccar.com/forums...tage-9911.html
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 04-30-2008, 12:41 PM   #4 (permalink)
Pushrod - '02 Chevrolet Cavalier
I think I'd rather have reverse along with injector shutoff.
Old 06-14-2011, 03:34 PM   #5 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I found this:
Free wheeling in your car
One of the comments claims that 1970's Saabs had a freewheel trans, until it was outlawed in the UK for safety reasons.
Old 06-15-2011, 03:51 PM   #6 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
You can keep reverse but you have to place the freewheel clutch between the engine and trans. The down side is if you need the engine to slow you down it can't, that can be fixed if you get a locking overrun clutch (I think that is hat it is called maybe a sprag clutch check wiki). I believe the two other issues you can run into are noise and shock on the clutch. The shock would be if you are coasting and suddenly need to speed up as the engine will spin up quickly till it hits the speed of the clutch then it will have the sudden transfer of torque. I'm not sure how bad that will be but if the parts are strong enough it should be able to handle it.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 06-17-2011, 11:34 PM   #7 (permalink)
One way / freewheel / sprag clutches are used in virtually every automatic transmission with the torque converter offering some shock absorbing characteristics.
Designing one to suit any car is simple enough and fitting is also straightforward.
I suggest locating it between the transmission out put and the final drive input so there is only one needed and fitting some sort of shock absorbing coupling (polyurethane?) is also reasonably simple.
just my 2c worth.
Peter.
Old 11-14-2011, 03:17 AM   #8 (permalink)
aero guerrilla
Piwoslaw's Avatar
The VW Lupo has a freewheeling 5th gear.
Old 11-14-2011, 05:38 AM   #9 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Only the Lupo 3L version has the freewheel in fifth gear .
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Reviving a 2000 Honda Insight "beater" Red Hybrids 215 08-10-2017 07:35 PM
How to smoothly bump start / clutch start an engine MetroMPG Hypermiling / EcoDriver's Ed 76 03-22-2014 07:52 AM
Shifting without using the clutch boxchain Hypermiling / EcoDriver's Ed 20 04-21-2008 08:34 AM
Lower your tires RR Lazarus EcoModding Central 1 12-06-2007 12:53 AM
