What do you think makes the vertical striatioins under the spoiler and tail lights and along the bottom?
The only thinbg I can thing of is inverse Cymatics.
Cymatics
Cymatics is a subset of modal vibrational phenomena. The term was coined by the Swiss physician Hans Jenny. Typically the surface of a plate, diaphragm, or membrane is vibrated, and regions of maximum and minimum displacement are made visible in a thin coating of particles, paste, or liquid. Wikipedia
The buffeting air is vibrating instead of the car. A tiny sucking sound.
"If you don't read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed. " someone who was not Mark Twain
