Old 07-26-2008, 11:29 AM   #11 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
Originally Posted by xbUser View Post
Thanks for your detail description and wonderful pictures. Sounds like the insulation would reduce the panel vibration, which improve the sound system quality, but not reduce road and engine noise level like Camry.
Believe it or not, your wheel wells generate the most noise and Camry is so quiet because its plastic wheel wells are coated with a felt like material that absorbs alot of the noise. From what I have read, do a bellypan, aside from the aero benefits everyone seems to say it cuts down on road noise as well...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 07-27-2008, 01:35 AM   #12 (permalink)
Box Dreamer
xB Commuter - '04 Scion xB
90 day: 40.76 mpg (US)
wow. sounds like worthy to do it. What material is the best for bellypan? Dynamat on chloroplast maybe a good idea, but too expensive.
Old 07-27-2008, 10:51 AM   #13 (permalink)
Most here use Choroplast, the sign material, which is a plastic. In the coming weeks I will be doing my bellypan out of Aluminum screening. Keep an eye out of the post, some have used that and say it works well. I have no issues with snow, or the such here so it would seem ideal for my conditions,plus help disapate the heat from the exhaust and engine.
Old 07-27-2008, 11:13 AM   #14 (permalink)
Box Dreamer
It is a good idea.
dynamat, heat, noise, reduction
