E10 vs Shell V-Power ( Benelux Europe )
I have been successfully comparing E10 which has become, the new Euro 95 in Belgium, The Netherlands and Luxemburg. My theory was, that because of V-Power not containing bio-ethanol. That I should be able to drive more fuel efficient.
Well it turns out it's true! So not a lie, which most car owners who can't control their right feet claim it to be. The V-Power is € 0,213 more expensive in Belgium, then the E10. Atleast at Shell Express Maaseik in Belgium. So it turns out I'm able to do almost 32KM/L when almost exclusively driving on the highway and paying attention to the real-time fuel consumption metre. With E10 I'm able to do max 27KM/L, so per KM tanking the V-Power actually makes the car drive more fuel efficient. Also see my Spritmonitor, I kept track of E10 for a longer period in the past and also tried cheaper Euro 98 from Gabriels. A discount fuel station, and the fuel consumption was worse than normal Super E5. I'm driving a Suzuki Celerio: Dutch Suzuki Celerio, with K10C engine and Cruisecontrol. |
Interesting, I'm usualy running 95 RON E5 from the cheapest local gasstation.
I figured that since my engine is NA and doesn't have a high compression ratio, anything more would be a waste. But I might run a test tank with higher octane fuel. |
The Suzuki Celerio is know as the most fuel efficient gasoline car, on Spritmonitor. Compression ratio of my car is 12:1 so higher than many gasoline cars. With the Super E5 I have been driving also very fuel efficient, but the only time I got 30km/L was when the Suzuki dealer added a injection cleaner to the fuel. Not all Euro 98 gasoline is free of bio-ethanol, but She'll claims their V-Power is. And I think the fuel efficiency is from the lack of bio-ethanol. |
Also my ECU is pretty dumb since my car is pretty old. Also 95 RON E5 is mostly 1,45-1,50€ here most of the time. I usualy get about 6L/100 km with my 1,8L engine and short gears. |
The increased price versus increased mileage suggests total cost involved versus bragging rights. |
1,50€/L is about 6,75$/gallon after all. |
Unless it's effectively required in order to avoid knocking, resorting to an octane rating higher than specified is overkill. It won't do any actual harm, but it's also not so likely to improve fuel-efficiency at all.
So I'm quite sure my car won't Profit from the higher octane level, that's why I don't even bother tanking V-Power Racing in Germany which is octane level 100. But the price of V-Power is higher in Germany, than Belgium. Take in mind, in Europe we use a different octane rating system than the USA. Also fuel is way more expensive. |
They discontinued the Celerio in Europe though: you can't buy them new anymore. Anyway I noticed that with V-Power the car runs more fuel efficient. I have been trying to drive as fuel efficient as possible, by sometimes pushing the limits.
I'm not sure how relevant this is, but I was recently at a rolling road session to map a 2 litre turbocharged competition engine for different set-ups:
- 102 Octane racing fuel with a 34mm diameter air restrictor - E85 Pump fuel with a 34mm diameter air restrictor (The air restrictor is mandated in some competitions to try to cap power outputs). With the same air restrictor, the engine produced 2.0% more power and 2.5% more torque when running on E85 compared to when it ran on 102 octane racing fuel. In both cases of course the air restrictor is the main limit to maximum power. We did not measure fuel usage rate on this test but experience during competitions shows the engine uses about 30% more fuel when running E85. We also ran a test using E85 Pump fuel with no air restrictor, but we didn't test the 102 octane with no restrictor. Removing the restrictor increased maximum power by 17.4% but barely changed the maximum torque (0.5% improvement). |
The real-time fuel consumption stayed, at 30KM/L while going up a slight elevation: yes my speed went down :turtle: But as soon as it went back down, the speed went up again and the fuel consumption stayed at 30KM/L. It didn't work with steep climbs though, although my car only has 68 horsepowers. I wouldn't do this kind of experiment on a weekday though, but on Sundays truck aren't allowed to drive on the Autobahn. |
I still remember when converting from gasoline to dedicated-ethanol was usual in Brazil when a naturally-aspirated engine got an aftermarket turbocharging setup, as it was much easier to mitigate knock. Cold start could become quite a PITA. Now that direct injection is more widespread in engines turbocharged from the factory, it's not much of an issue as it used to be.
This reminds me that Jaguars used to have twin tanks with a dashboard switch to select which one to use. Is there any milage (pardon the pun) in adopting that approach as a mod? Perhaps use one grade of fuel for starting or faster driving and a cheaper grade fuel for easy cruising. Has anyone done anything like that? |
The difference in energy content between pure gasoline and E10 is approximately 3%. I've been able to measure an approximately 3% difference in fuel trims in my vehicle - I made separate fuel maps for ethanol-free fuel and E10.
Here in the 'states, E0 is almost always high octane "Premium" fuel. If you need to run high octane fuel anyway it's an obvious choice, but it does not pay for itself vs regular grade. @Zunigrijje, your 18.5% improvement doesn't line up with the energy content difference between the fuels, or what I've been able to measure in my own vehicle. |
Perhaps the car also simple runs better on the V-Power? I'm not really a car expert, but one thing I noticed is that my car runs better on normal Super E5 ( available in Germany ) and on the V-Power, it runs even better.
Not sure if I'm finally able to post my Spritmonitor, I guess not? But with E10 the consumption is really worse, max 27km/l vs 31km/l that I was able to get max with the V-Power. spritmonitor.de/en/detail/915384.html |
I can only speculate, honestly. On the one hand, whatever works. On the other, maybe you can do some investigation? See if your economy is half better with half a tank of each?
Yes clearly you need to try it: I also tried discount Euro 98 and had worse fuel economy, than with normal gasoline.
People are even washing ethanol out of fuel ... Less energy in ethanol than in fuel Quote:
Same goes for Total Excellium fuels V-Power diesel and equivalents from other brands, never were a valuable option: You could never get the price premium back through reduced fuel cost Quote:
But if correct, almost 1/5 increase in FE for 1/7 increase in price is a profit |
(alcohol also raises octane, but yeah ... that doesn't say it all) And the car might be set up for it - see instruction manual Quote:
I've used them before This is where to find it: https://ecomodder.com/forum/member-e...8-22-13-38.png You can also control the units to be displayed - I use L/100km For my van, it looks like this: (URL=https://www.spritmonitor.de/en/detail/1124642.html] (IMG]http://images.spritmonitor.de/1124642_5.png[/IMG)[/URL) Replace ( and ) with square brackets before and after URL and IMG |
I couldn't post Spritmonitor because of not having enough posts: anyway I also filled up with V-Power in Luxemburg, it's about € 0,22 cheaper. The high record of 31,6KM/L I was not able to maintain, perhaps also because I got my airco condensor fixed and I can imagine it hurts fuel economy a bit when your car is being fixed.
The last two fillings where both 29KM/L but that's combined use, where when I set the record: it was only highway and not city roads at all. I must say though, the price in Belgium has been going up and it hasn't go down anymore. https://www.spritmonitor.de/en/detail/915384.html |
Hmm, in my station the V-Power shell has E5. And in Suzuki there is almost no difference in fuel consumption, but the manual says to use 98PB or higher if the temperature outside will be higher than 30 degrees. Only above 30 degrees outside, the use of 98Pb reduced fuel consumption by an average of 0.5 liters less.
Yes, in a naturally aspirated one, it responded better to the addition of gas and burned less. And in Turbo, he also reacted better, but combustion was unchanged, worse when the rain falls, the fuel consumption increases ... even at a standstill, instead of 0.5 l / h, it shows 0.9l / h ...
direct injection
Even though direct injection is often pointed out to bring spark-ignited engines closer to a Diesel-like efficiency, it's surprising a higher amount of moisture has such an opposite effect.
Nearly 50mpg
G'day as we say here in New Zealand.
I have a Suzuki 1.4 liter Baleno Automatic and with my Eco driving a get 21.2kml that is 4.72liter per 100km or 49.9mpg US or 59.9mpg UK. so I think it is possible for me to get 50mpg US or 60mpg UK, I hope so. |
Nearly 50mpg
I have the tires pumped to 38psi but what is a ''Splitter/diverter'' and where do they go ?
Thanks.
On the front and rear of the underbody, respectively. There is a Search field in the upper left, for what it's worth. Quote:
Nearly 50mpg
I did put an factory sourced undertray under the engine a couple years ago but nothing at the back underneath as there is not much to change under there with the airflow I think but please tell me that I am wrong.
