Old 12-28-2013, 07:00 AM   #1 (permalink)
Delivery 'Boy - '86 Suzuki Mighty Boy
90 day: 37.15 mpg (US)
SkipSwift - '13 Suzuki Swift GL
90 day: 35.44 mpg (US)
E85 in a diesel dual-fuel?
I keep hearing about adding a second fuel for diesels. Basically use the diesel injector as a hugely powerful spark plug to ignite a high octane fuel.
Is it conceivable to run E85 as that secondary fuel? With an already occuring flame front surely you could ignite ultra-lean mixtures and keep the whole 'fuelling controls load' thing going on, with a relatively simple injection system...
Note that E85 is not available at a bowser within 1000 miles of me, I have no idea of its pricing so it may not be viable. But is it possible?
Originally Posted by Crazyrabbit
In God we trust. All others: bring data
Old 12-28-2013, 08:37 AM   #2 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
This was done by MIT, when using diesel dual fuel you can run hydrous ethanol even in the winter and get away with a non turbo diesel and still have 300+hp. Too bad the emissions folks hate multifuel engines with a passion.
Too bad chevy wouldn't re-engineer their old olds cast iron diesel into a 2.8ltr DI dual fuel, 300hp and naturally aspirated diesel fuel economy would be a welcome change.
Add atkinson cycle and remove the urea
Old 12-28-2013, 07:26 PM   #3 (permalink)
I'm not sure you could have 300hp in any passenger sized diesel without boost... I mean they simply don't rev hard enough for their displacement. Unless you could modify one of those 350 chev diesels... However without the limits on detonation or lean-burning you could certainly do some interesting things.
By hydrous ethanol do you mean mixed with water?
Actually, how does water/alcohol injection work on a diesel when there is no extra fuel added through the pump (i.e. it all comes with the water/alky mixture)?
I have a plot cooking... Give me a few minutes to clear up exactly what my idea is, then a couple more to type it down...
*edit: Plot not feasible for my own testing. But... Mix ethanol and water into regular unleaded for low energy content buy high octane fuel?
Old 12-29-2013, 07:00 PM   #4 (permalink)
It's viable to use an ethanol secondary injection, but I'd rather do it with either E100 or E96h. BTW Iveco is testing a dual-fuel Diesel-E96h truck in Brazil in partnership with Raízen (a joint-venture between Shell and Cosan, one of the biggest ethanol producers in the world).
Anyway, you might remember Scania already makes some compression-ignition engines powered by ethanol, and altough they're not E85-certified they may eventually work with it.
