Old 09-05-2009, 12:57 PM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
easy 3d scanning?
With the talk about digital flow modelling (i.e. openfoam), I've just been toying with simple ideas for scanning vehicles into the computer (on the cheap of course), looks like these folks actually put something together. Just need a hand held line laser, web cam, and a backdrop. Wonder if it could work on a metro (certainly the concept could be applied to a metro)?
FYI, only the low-res version is free, probably something similar in open source land too.
DAVID 3D Scanner
The Following User Says Thank You to dcb For This Useful Post:
Cd (09-06-2009)
Old 09-10-2009, 04:59 PM   #2 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Thank you so very much for posting this. Made my day.
Old 09-09-2011, 12:55 PM   #3 (permalink)
That's still over $900 in US dollars, right?
Old 09-09-2011, 01:03 PM   #4 (permalink)
If you use 3D scanning on a car model, it would make sense to build a half model, scan it, and then mirror the other half. Symmetry is tough to do by hand.
I could have used this to start my CarBEN EV model...
Old 09-09-2011, 01:42 PM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
I was thinking of scanning actual cars, not models, then doing your aerodynamic tweaks on the computer and simulating to derive the drag/lift coefficients, tweak and repeat. If your car in your driveway actually isn't quite symmetrical, then the simulator needs to know that.
Old 09-09-2011, 02:10 PM   #6 (permalink)
doviatt's Avatar
Grey Goose (Retired) - '89 Geo Metro LSI 4 door hatch back
Last 3: 57.16 mpg (US)
Tweety - '91 Geo Metro Convertible -2 Door convertible LSI
90 day: 43.97 mpg (US)
Shadow - '02 Honda Shadow VT1100
90 day: 43.46 mpg (US)
Sonic - '07 Honda CBR1000RR
90 day: 42.69 mpg (US)
Filmore - '84 Volkswagen Vanagon
90 day: 20.9 mpg (US)
I ran a 3D scanner for about a month. It makes a point cloud file. Lots if data points depending on your resolution. You have to then import and model around the cloud info. Easier said than done for super accuracy and lots of surface detail. Small parts are easier. Large parts like a car would require stitching of the cloud info as you are limited on the scan size and distance away.
Old 09-09-2011, 04:09 PM   #7 (permalink)
...beats walking...
...memory and terabyte harddrives are cheap!
...but, quoting Microsoft"...Who's gonna use more than 64KB of memory anyway?"
Easy Aero Fix? (Modding a pickup?) DifferentPointofView Aerodynamics 53 04-13-2012 05:46 PM
open 3D cad? dcb Forum News & Feedback 2 04-16-2009 08:41 AM
Mounting 3d party GPS bwilson4web Instrumentation 8 04-13-2009 01:53 PM
Scanning the EM Garage... and reminiscing about the 74 gas crisis akcapeco EcoModding Central 8 07-11-2008 12:53 PM
