Old 12-21-2015, 04:41 PM   #11 (permalink)
open-faced radius
Originally Posted by oldtamiyaphile View Post
You don't have to enclose the sides, an open sided half pipe will work nearly as well. There's a company actually making and selling them like that.
BamZipPow (12-21-2015)
Old 12-21-2015, 05:00 PM   #12 (permalink)
upper splitter
If the top of the trailer is taller than the tow vehicle the splitter could create some positive lift,especially in a crosswind.
The air won't be able to bleed 'up',and as the dynamic pressure acts on the underside of the splitter it will be pushing upwards,affecting tongue weight,stability.
Something more stable,would be to split a 8" PVC pipe and attach the halves to the upper edges of the trailer face.This would be incapable of generating lift.
BamZipPow (12-21-2015), bluebunny (12-21-2015)
Old 12-22-2015, 07:11 AM   #13 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Also, Hucho suggests that a vehicle mounted deflector is worth more than re-profiling the top of the trailer. This could be roof mounted on a removable roof rack. He shows a fast back vehicle towing a caravan, with a large roof mounted deflector showing the lowest drag.
Old 12-22-2015, 02:41 PM   #14 (permalink)
This puts me in mind of the Triceratops...
https://en.wikipedia.org/wiki/Triceratops#Growth_and_ontogeny
Juvenile Triceratops has an epoccipital fringe (that disappeared in the adults) similar to the serrations on modern turbojets used to suppress noise.
...on the back of a 1948 Cadillac Sedanette.
Old 12-22-2015, 04:34 PM   #15 (permalink)
deflector
Old 12-23-2015, 08:13 PM   #16 (permalink)
Hard to do since the front face has a curve in it.
That's a pretty small car towing that trailer, heh.
Those roof racks are interesting, but we aren't seeing what is happening at the trailer sides, with a cross wind, etc.
Isn't it true that almost any trailer shape generates lift? The way those streamers look in those pictures are similar to what happens with a wing. Added speed of air over the top causes reduced pressure, which means lift...
Old 12-24-2015, 03:45 AM   #17 (permalink)
Almost any typical trailer but not almost any conceivable trailer.
This is a Luigi Colani Bonneville car that obtained massive downforce without add-ons. Except the fenders are sort of add-ons. Flat on the top and convex on the bottom. Translated to trailer terms — sort of an upside down Airstream.
maybe aerohead will come along and say whether Airstreams have any lift to start.
Old 12-24-2015, 11:21 AM   #18 (permalink)
Dark Egg - '12 VW Touraeg
I think any lift generated is just a tiny fraction of the weight. We aren't talking lightweight aircraft, and we aren't talking aircraft speeds. An airstream is actually a heavy trailer compared to some of the stuff made today.
I used the sheetmetal ductwork for my edges. If it were a curved surface you could cut some relief cuts in it to let it bend. They could just be simple cuts almost all the way across just leaving an inch in the center intact then they will slide inside themselves like an armadillo skin as it makes the bend.
Old 12-24-2015, 01:22 PM   #19 (permalink)
The center 80% in lightly curved. If you have an half-pipe and spread the center or pinch the ends, it curves. On the ends if you don't want to use Hersbird's pie cuts, crimp the edges. There is a dedicated hand tool. But you can just grab the edge with a fork[-like object] and twist. That's how panel beaters start, then they hammer the crimps flat again.
Old 12-26-2015, 12:13 PM   #20 (permalink)
lift
In road vehicle aerodynamics,lift is a function of flow separation,and the low pressure over the vehicle induced by low pressure present at the separation line.It has nothing to do with the displacement of the streamline filaments.
In the image below,the top vehicle would be extremely unstable at speed,whereas the bottom vehicle would be especially stable.
Streamlined bodies are incapable of generating lift,as they have zero separation,or recover with reattached flow.
The Following 3 Users Say Thank You to aerohead For This Useful Post:
freebeard (12-26-2015), Nonhog (03-24-2017), rumdog (12-26-2015)
