Ecky's JDM Insight
EDIT: New Insight purchased. See page 4 for the start of my ownership.
https://i.imgur.com/wPl6naV.jpeg ~ Recently I've taken interest in getting another Insight. Fuel prices are on the rise, and 58mpg highway from the convertible just doesn't cut it for the occasional weekend trip. Plus, there have been some interesting developments in the Insight community. Example: https://www.insightcentral.net/threa...oldest#replies Essentially, what's available now is the ability to use lithium batteries, and to fully control the IMA (hybrid) system. It can even be operated without an engine running, or even attached - it's fully independent from the engine ECU. 12kwh of lithium batteries fit in the same space as the OEM ~1kwh nickel battery, for very little extra weight, and could give something like 2 hours of continuous mild electric assist. I foresee 200mpg+ tanks being possible on road trips, with negligible electricity use. The price is also reasonable, with everything (except the car) coming in potentially under $3,000usd. I've begun inquiring locally about batteries and looking for a suitable car to build. Unfortunately, Insights are extremely rare in New Zealand, with perhaps only 25 ever having been imported here. ~ Further down the road, it's possible to change the engine out while maintaining a fully functional hybrid system, that can even stop/start a donor engine. Any Honda L series should bolt up, possibly even including the 1.5L turbo in the recent Civic and Accord, or the Atkinson cycle 4 pot from Honda's other hybrids. I'd also have my pick of any L series transmission to bolt to the other side of the transmission. The CR-Z's 6 speed looks promising, though it would be in want of a taller final drive gear. A wild idea, but with an adapter plate between engine and transmission, a Honda K series turbo plug-in hybrid would even be possible, though I have no idea what I'd do with it. |
Were the insights there all originally in Japan then imported?
More interesting is the different gearing! Shorter 3rd gear and final drive. https://www-honda-co-jp.translate.go..._x_tr_pto=wapp |
I still remember when you were lurking about taking your US-spec Insight with you to New Zealand. Most likely shipping from Japan, if you could still find one there at those JDM car auction sites, would've been cheaper than taking yours to New Zealand. But anyway, AFAIK it was already eligible for import despite the LHD cockpit. I'm only uncertain about the US-spec symmetrical headlamps being allowed there.
Here's a comparison of the gear ratios, if that is in fact true: https://i.imgur.com/GsVJxxD.png https://i.imgur.com/ahyu0jl.png It essentially resolves my only gripe with the stock North American version, which is that the gear spacing was uneven, and 1-2-3 were wide while 3-4-5 were closely spaced. Cruising at 100kph, USDM would be 2120rpm, whereas JDM would be 2240rpm. Shifting at 2000rpm, the shift points would be: USDM: 1>2 - 19kph (12mph) 2>3 - 38kph (24mph) 3>4 - 61kph (38mph) 4>5 - 77kph (49mph) JDM: 1>2 - 18kph (11mph) 2>3 - 36kph (22mph) 3>4 - 54kph (34mph) 4>5 - 74kph (46mph) Torque would be 6% higher in each gear, except 3rd, which would have 12% taller gearing. I wonder if 3rd gear was changed for the US market to beat the EPA test? |
A further bit of math - accelerating from 1500rpm, stock, is 60ft-lbs from the engine, plus 36ft-lbs totaling 96ft-lb.
With lithium, that assist is increased to 72ft-lbs, totaling 132ft-lbs. Assuming accelerating in 3rd gear, which is the typical passing gear on the highway, along with 12% shorter gearing, it would feel like the the stock car has 148ft-lbs, or 54% better acceleration. |
I wondered how long you'd last before you wanted to get another Insight. :) It's been 15 months since I sold mine; I miss it but 60-70 mpg in the Prius C and < $3/gal gas with discounts isn't motivating enough for me to get another one. What are NZ laws like on importing cars? Any restrictions on usage, rarity, or age?
Lithium conversion is definitely tempting, and it looks like the relative simplicity of the Insight's system is allowing it to be more reliable and robust than the attempts at converting the Prius to run on lithium. |
As far as imports, vehicles newer than a certain point need to have traction control and be right hand drive, but the Insight is old enough to be exempt from these. Additionally, any vehicle going on the road needs to pass an inspection. Many modifications would fail a car, but nearly all stock cars, in good working order, from any market, will pass. Generally if it's good enough to be sold in Japan or Europe or North America, it's good enough for here. |
