Old 01-10-2020, 10:01 AM   #21 (permalink)
It's easy to "remove" the turbo from the car, simply unhook the wastegate actuator arm from the wastegate.
The wastegate will remain open and create zero boost.
Old 01-10-2020, 03:21 PM   #22 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by Andrei_ierdnA View Post
This is a fun scenario to consider, but only as a hypothetical concept.
From a practical point of view it would be absolutely terrible (even dangerous) to drive a 2,800 lb car with a 1.0 liter 3 cylinder NA engine in the US.
It would have a 0-60 mph time of 60 seconds, going downhill with a tailwind.
I really don't think it would be "dangerous". I mean people drive Mitsubishi mirages...
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 01-10-2020, 08:46 PM   #23 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
It's worse than that. Car & Driver reported that their 2015 Focus Ecoboost sedan weighed 2,972 lbs!
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 01-13-2020, 04:54 PM   #24 (permalink)
I do know the civic before I sold it would misfire over 70-75% load and I kept it between 1750 and 2300 so I honestly think the math would probably work out to I had maybe 30 horsepower. From the memories, I had yeah that's probably correct. lol
A lot of momentum driving. Could maintain everything except those semi passing lanes up hill, and torrential downpour interstate at 70 mph. But it also weighed 2400lb and had a better drag area than the focus. So probably compare it to a 50bhp Focus.
Fun fact the focus makes 1.6 bar of boost. If you divide that down that is 78bhp naturally aspirated ish. I don't think thats dangerous.
