07-28-2009, 06:38 PM
#21 (permalink)
All of this stuff is cool...great work!
For ecomodders I think the data you are working on is awesome...the more the merrier! It's really a chance to "show off" to the gas guzzling crowd and good info. for us to provide to the media to generate interest.
For non-ecomodders I think easy to understand graphics are the way to go (graphs, charts, flashy things). Kind of like ecomodder for dummies to make outsiders attracted to joining the cause.
Again...outstanding work...can't get enough of the site stats, Top 10's, etc!
07-28-2009, 07:02 PM
#22 (permalink)
Dartmouth 2010
Thanks for the support. Hopefully once we have all the stats we want to use ironed out we can integrate them well into the site
07-28-2009, 11:28 PM
#23 (permalink)
Dartmouth 2010
Something is up with the june/july stats, not sure what exactly, but I'll work on finding out.
Anyway, here's the first graph: http://ecomodder.com/flash/ofc.html
07-28-2009, 11:31 PM
#24 (permalink)
That graph is working for me...what did you see with June and July?
07-28-2009, 11:37 PM
#25 (permalink)
Dartmouth 2010
Well, the points for 7 and 8 are the same, which is an issue
07-28-2009, 11:44 PM
#26 (permalink)
Yeah...I got that too...possible both months are exactly the same mpg? Do you have data that suggests they are not the same mpg?
07-29-2009, 12:03 AM
#27 (permalink)
Dartmouth 2010
Fixed it...
Long story short. I was comparing strings and for some reason it was saying 00 equaled both 08 and 09 but that 08 and 09 didn't equal either 08 or 09, and showing for those months the results of the fills that had no associated date. Anyway, after much messing around I fixed it and the graph is now accurate. Not as dramatic as could be but it gets across the point all right.
Graphing is hard! But hopefully from here it'll get easier
07-29-2009, 02:03 AM
#28 (permalink)
aero guerrilla
The months in the graph are numbered 0-11, instead of 1-12. Of course, as a mathematician I've no problem with that, but Jan, Feb, Mar, would probably be best if it's possible to change that.
07-29-2009, 11:37 AM
#29 (permalink)
Dartmouth 2010
Yeah, I've been trying to figure it out. There's no good quality documentation for the flash graphing software I'm using so it's a bit like wandering around in the woods.
07-29-2009, 03:07 PM
#30 (permalink)
aero guerrilla
Watch out for wolves, Little Red SVOboy.
