Old 03-11-2008, 11:37 AM   #1 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Homebrew Cylinder Deactivation
I can't do this on Josie, she's carbureted. But my Subie has individual injectors, and a lot of other cars out there do.
Aftermarket power chips are everywhere. Is anyone doing custom programs that would shut down some of the injectors under low-load conditions? I know most of the aftermarket chips are intended to increase power output with longer injector-on times etc, but if the programmers can do that, then surely they can go the other way?
I ask because I rented a new Impala for Thanksgiving that got about 28mpg at 75mph - that's great results for a big car making good time. That big V6 would switch to three cylinders and back again; I never noticed unless I checked the data panel. Imagine what I could get out of a smaller, older - and paid-off! - car if I could just install an aftermarket ECU chip that would shut down cylinders 2&4 at steady-state cruising?
Old 03-11-2008, 03:15 PM   #2 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Frank knows it! I think pulling a couple pistons/rods or picking up a spare cam and grinding the lobes off is easier than repositioning the oxygen sensor. Speaking of which, are there any cars that have the Oxygen sensor in one of the runners and not in the manifold/downtube?
Cylinder deactivation discussion diesel_john EcoModding Central 87 03-10-2014 06:42 PM
Pulse and Glide Fuel Economy Calculator 4 valve / Cylinder newtonsfirstlaw DIY / How-to 25 11-04-2008 03:32 PM
direct cylinder injection oldschool EcoModding Central 3 02-24-2008 03:04 PM
Video: first high voltage power up: Mazda RX-7 with homebrew controller MetroMPG Fossil Fuel Free 1 02-10-2008 10:17 PM
