Old 06-23-2019, 03:37 PM   #1 (permalink)
Dark Egg - '12 VW Touraeg
40.6 mpg in a full size Chevy pickup
Car and Driver got ahold of a 2020 new 3.0 diesel inline-6 Silverado and managed to squeeze 40.6 mpg out of it on the backroads of central Oregon. They I don't think say exactly if that was a crew cab 4x4 version but it looks yo be in the pictures. That's pretty respectable with also the ability to tow over 9000 pounds.
https://www.caranddriver.com/reviews...-diesel-drive/
Old 06-24-2019, 12:32 AM   #2 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
now it just needs hybrid 2 mode with a 10 speed automatic CVT( CVT only runs the electrical power plant ) and they are well built like the toyota ones
and get 60MPG
Old 06-24-2019, 01:04 AM   #3 (permalink)
90 day: 29.78 mpg (US)
Sounds like the truck I'd want. I bought the smallest diesel truck I could at the time, which was the 5.9L Cummins. Crazy how this 3L puts out more power while being more efficient. Of course, I'd rather have hybrid tech than a fancy diesel at this point, but the truck companies are afraid of offending their base.
Old 06-24-2019, 03:54 AM   #4 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
40.6 average or just a high instant figure?
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 06-24-2019, 05:31 AM   #5 (permalink)
90 day: 19.36 mpg (US)
Not enough specifics to know how 40 was hit. Least amount of throttle changes also means preventing brake use. It’s knowing how to glide. (A/C off is funny. And unnecessary)
The real secret is that with a 10-speed auto trans and variable-vane turbocharger that drivetrain software programming is mature to the point that MPG figures from just a few years ago are no longer relevant.
The 2019 Peterbilt I’m in is set for a van aerodynamically. 13L PACCAR I6 and 12-speed PACCAR Automated Manual. Bobtail, with maximum fuel (220-gls), driver & drivers gear this tractor scales at 21,500-lbs. (Extra insulation and an 8-battery setup that uses [4] AGMS to run sleeper A/C).
With no adverse winds I can run the Interstates while bobtail out on the Plains at an indicated 14-mpg at 67-mph at the usual 1,150-rpm cruise. I’ve a friend with a fairly recent Duramax Silverado does that same mileage. A 9k pickup with a 6.6L engine & six speed.
With an aero package van and barest tailwind — plus 30k in the box — I can be in double-digits.
The difference between the 10-speed 2015 I was in and this one is impressive. It’s just THAT much better at every transition. It’s not quite enough to say that the trans is the biggest difference for that pickup.
And FWIW, the C&D comment about more for less (9,300-Tow Capacity) has for the likely RV owner/buyers a thump to the head about today’s granite-counter, slide-out junk bad-aero boxes that WEIGH TOO MUCH.
My 1989 35’ Silver Streak weighs less than the TEN FOOT SHORTER current Airstream 25’. The aero problem for both is fixed, but there’s almost nothing to functionally justify this piggish weight increase.
Similar to this half-ton in power, my ‘04 Dodge at 305HP/555TQ is vastly overpowered for the job of moving this 17 to 18k pound combined rig down the highway.
Being slower on the ascents is only a problem for the pussies.
I’d guess this truck, like the Dodge V6 diesel, is going to be wound pretty tight. Always on the job. Wholly unlike my Cummins Six.
Reading PERCENT ENGINE LOAD and never exceeding 80% is where a true-er test would start. This type of programming (and gearing choices available) will put it to the wall almost immediately. Would be best to forego that solo. And learn when to use and NOT to use while towing.
The reason for 13,15 & 18-gear transmissions in big trucks was to keep the engine in the sweet spot. Always. Road speed didn’t matter very much (relative to acceleration rate).
We’re going to hear “lousy” numbers from those who can’t be bothered to learn how to solve the problem by adjusting their bad habits. It’s all about feelz these days. And it’s embarrassing. “Men” with the fortitude of women or minorities. (The Churchill quote about, you’ve never really been to war unless you’ve fought the Germans. Yes, for problem-solving, the NCOs and enlisted were given goals. And left to achieve them).
The most for the least isn’t up to the vehicle. And an empty pickup isn’t any test at all.
Old 06-24-2019, 05:38 AM   #6 (permalink)
if you want a high instant figure I'll Raise you to Infinite ∞ instant figure for the next mile or so
Old 06-24-2019, 08:39 AM   #7 (permalink)
Redneck Ecomodder
I6 diesel
Almost enough to make me interested in a Chevy.
Almost....
Maybe in 20 years when I could afford one of these.
Old 06-24-2019, 09:43 AM   #8 (permalink)
If it is the same system that uses some variation of the isuzu 6 banger, maybe. Box trucks have been flogging that for years.
Otoh, the fuel computer in the Golf says we hit 60mpg flat and level at 80 mph, SOOO, I don't think so.
Old 06-24-2019, 07:37 PM   #9 (permalink)
That was an average, they explain in the article, backroads, never above 60 mph, no a/c, ect.
Old 06-24-2019, 07:41 PM   #10 (permalink)
Originally Posted by Shaneajanderson View Post
I6 diesel
Almost....
I6 is the way God intended engines to be built, gas or diesel. It's even better if they are opposed valve design so the intake is opposite of exhaust.
Like this little number from down under.
The Following 3 Users Say Thank You to Hersbird For This Useful Post:
Daschicken (10-13-2019), Shaneajanderson (06-25-2019), slowmover (06-26-2019)
