Old 03-03-2010, 12:07 PM   #1 (permalink)
Torontocity's Avatar
Transmission Choice
Hi All.... I have a transmission from a GM Gas Engine connected to a Mercedes Benz Diesel Motor,
My Question is...If i Put on a Tranny from a GM Diesel Motor with Diesel Torque Converter...Would that make a difference???
see here
Thanks!
Old 03-03-2010, 04:38 PM   #2 (permalink)
Whoop's Wheels - '89 Honda Civic Wagovan
90 day: 39.09 mpg (US)
Without doing any research, this is a educated guess, but here it is.
Yes, if you switch it over to a transmission from a diesel, it would work better and get better mileage. The diesel motor is optimized at a lower speed than a gasoline engine. They typically accomadate these differences in the transmission and/or the differential.
If they made the accomadation in the differential, then you should be able to just switch the differential out, for one that is geared for a diesel.
The one thing you will also need to find out, if you make either of these changes is what change you will also need to make, to get the speedometer to report the correct speed.
I hope this helps, a little.
The Following User Says Thank You to Whoops For This Useful Post:
Torontocity (03-03-2010)
Old 03-03-2010, 05:26 PM   #3 (permalink)
Thanks...seems reasonable...the speedo is located in the transfer case, so i"m getting accurate speed reading.(ps) i tested it with a GPS Also...
Old 05-30-2010, 08:57 PM   #4 (permalink)
UPdate! Yes....Had a Diesel Torque Converter made and the take off is MUCHO better,
runs the same otherwise.
Old 05-30-2010, 09:38 PM   #5 (permalink)
Wasn't the suburban already available with a diesel engine from the factory?
Old 05-30-2010, 10:37 PM   #6 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Bump for worlds best Suburban.
How did I miss this? Subscribed:
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 05-31-2010, 10:22 AM   #7 (permalink)
Yes...but with a 6.5 diesel....Not the best choice....Loud Guzzle Stall..............
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 10:41 PM
Tesla Roadster's 98% efficient transmission nominated for innovation award MetroMPG Fossil Fuel Free 20 12-20-2009 01:51 PM
Synthetic transmission fluid for a manual transmission? abcdpeterson General Efficiency Discussion 15 10-12-2009 08:56 AM
