Old 09-03-2014, 07:50 AM   #1 (permalink)
Recommended front-end suspension rebuild on a 92' Civic VX
Hey all. Hope your labor day holiday was less laborious as mine. Cutting to the point, I just had new tires installed yesterday and the tech showed me something very troubling. He gripped my wheel/tire and shook it vigorously showing extreme play and wobble. Suffice to say, my front end is shot. But I'm curious on which components (or which are crucial to having a proper alignment) I should replace. Tire rods, control arms, even wheel bearings? I also plan to buy the parts from rock auto.com, but when I browse their inventory, I don't see VX listed as a model but a lot more of the CX LX etc. Are the suspension parts in question interchangeable between all of these trim lines? And if not, which are the VX compatible with?
Thanks so much for any help.
Old 09-03-2014, 10:39 AM   #2 (permalink)
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
You local tech can show you which parts are worn. Those are the parts you need. My guess is outer tierods first and maybe the lower ball joint. Also look at the rubber bushings at the inner pivot of the upper arms.
All these parts are interchangable within the model generation (ie 96-00)
Old 09-04-2014, 07:27 AM   #3 (permalink)
Yeah pretty much was I was going to do. Thanks for the info on interchangeable parts too.
