Old 05-02-2012, 01:07 AM   #11 (permalink)
Ford Escort 2.0
TomEV's Avatar
Electricar - '89 Ford Escort LX Hatchback
I installed the J1772 inlet and control board in the Citicar tonight - Works as advertised!
Perhaps the first time a Citicar has charged up using a J1772 charging station... It will be nice to be able to use the J1772 only charging stations that are going in - At first, many were dual J1772 and 120v, but all that I've seen being installed recently is J1772 only - Not much use if you only have a NEMA conductive plug-in...
Right now it is at Version 1.0 - Works, but could use some aesthetic improvement.
The Following User Says Thank You to TomEV For This Useful Post:
Ryland (05-02-2012)
charger, citicar, elcon
