Old 05-26-2008, 01:02 PM   #1 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
Electric 5th Wheel
Hey guys, here is another crazy idea I wanted to run past you all. Since my car is 99% hwy driven I was thinking about creating a 5th wheel unit that was powered by and electric motor. However I would only engage it once I was up to hwy speed to maintain 65mph. I know its possible with gearing and such but what would happen to an electric motor going from 0mph and being dropped to maintain 65mph? I can work out the logistics for batteries and such later, but this is the first question I had ..
Thanks
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 05-26-2008, 01:58 PM   #2 (permalink)
amateur mech. engineer
Sporty Accord - '88 Honda Accord LX-i
90 day: 23.25 mpg (US)
Dad's Camry - '01 Toyota Camry CE
90 day: 22.81 mpg (US)
The E-wheel
It would be smart to power up the motor and have the wheel match the road speed before lowering the wheel to the pavement. Otherwise the tire would get a lot of wear as it skids before it speeds up to 65 MPH. You will probably need at least 20 HP to go 65 MPH. That is about 15 KW.
A regular gasoline engine is pretty efficient when going fast. When you go slow you can save energy by turning off the engine and using electric power.
Somebody else has this idea also. He calls it the E-wheel. You can read about it at <http://www.99mpg.com>.
Old 05-26-2008, 02:26 PM   #3 (permalink)
Similar to that obviously, but better. I will have to use a trailer wheel, which handle handle the load and speed and in my case running it @ 65mph would be most efficient for me since I run 60 miles one way to work each day on the highway. So 60miles @ 800 rpm is much better than 60mph @ 2200 rpm.
But i guess the answer is that I have to get the tire up to speed before it hits the floor? The wear on the trailer wheel is insignificant really, they cost next to nothing, but I am more oncerned about damaging an electric motor.
Old 05-26-2008, 03:37 PM   #4 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
might look in to the AWD Vibe bits, could drive the existing 2 wheels, just another crazy idea to go with yours
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 05-26-2008, 04:07 PM   #5 (permalink)
Great IDEA !!! I forgot these things come AWD ...
Old 05-27-2008, 12:51 AM   #6 (permalink)
EV OR DIESEL
That's what I'm here for :-)
I want to do an r32 back half in the Golf bad. Couple it with a electric clutch and a small (6.4") motor and 7 12 volt cells .
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Old 05-27-2008, 12:58 AM   #7 (permalink)
Piaggio Fly 150 - '10 Piaggio Fly 150
90 day: 64.8 mpg (US)
Your ICE is already pretty efficient at maintaining a set cruise rpm (much more than stop and go). Electric motors at highway speeds burn up amps pretty quick so you are going to need a lot of batteries. I honestly don't see you having much of a gain from this system... I would go with electric at low speeds and kick the ICE in for highway. Or if you swapped out your motor for a smaller one you could cruise with higher throttle openings and just use the electric for the occasional times you need to pass someone or go up a hill. If you want to improve mpg you've gotta match the strengths of the different motors to their tasks.
Check out my Green Cars Blog and the DIY electric car Wiki. Enjoy!
Electric fifth wheel (DIY through the road parallel hybrid) friedlbug Hybrids 41 10-14-2019 10:22 PM
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Article: Electric Subaru Due in 2009, One Year Early MetroMPG Fossil Fuel Free 8 08-29-2009 12:19 AM
electric bicycle... johnpr Fossil Fuel Free 0 03-03-2008 12:07 PM
Front VS Rear drive on electric bennelson Fossil Fuel Free 18 02-03-2008 03:10 PM
