Old 01-22-2010, 04:04 PM   #11 (permalink)
allc0re's Avatar
The Truck - '00 Ford Ranger XL Ext. Cab
90 day: 24.94 mpg (US)
Send a message via AIM to allc0re Send a message via MSN to allc0re
Originally Posted by mikeross View Post
i have a ranger too.. and i am thinking about doing the same thing.. changing the belt fan to an electric one.. about how much would the parts cost? thanks
I got all I needed for about 70 bucks. The fan from a yard, the relay kit from Autozone and the mounting stuff from my collection of nuts and bolts. Even if it takes the life of the truck to break even, it makes me feel better and that's worth every penny.
Old 07-07-2010, 05:25 PM   #12 (permalink)
relay info if you can spare the brains?
howdy,
i have the same t-bird fan and am trying to find our what amperage and if you used a thermostatic probe for the fan....in short, how'd you hook it up?
thanks...i think the temp range is 190-210? but need to find a correct amperage relay etc...and just put the proble in the radiator fins?
thanks for any/all help!
Old 07-08-2010, 11:14 PM   #13 (permalink)
allc0re's Avatar
Originally Posted by andre4999 View Post
howdy,
I just bought a standard fan relay kit at Autozone; I'm not sure of the current. I hooked the +12 volt lead directly to the battery and the -12 volts to a good ground. Then I fount an ignition-switched voltage source for the accessory wire (I used one from the wiper motor) and hooked up the A/C wire to the compressor. There is a temperature probe and that goes in the radiator fins near where the coolant comes out of the engine. Mount the relay itself somewhere (I screwed it to the fuse box cover) and you're all set. Hope that helps!
Old 05-01-2014, 10:07 AM   #14 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
lower hose temp switch + brake light circuit
Originally Posted by brucepick View Post
I did an e-fan conversion on my rwd Volvo 240 with 2.3 liter engine. It seemed to help FE.
Toughest part was managing the fan switching. I too wanted to mimick the constant breeze of the belt fan without excessive operation of the e-fan. I ended up very happy with a relay link running off the brake light circuit. When not moving or when crawling in traffic, the fan runs on low speed.
I added a temp switch in the rad lower hose (return hose) which is set some 20 deg. F cooler than the engine thermostat. So if the water from radiator isn't sufficiently cool to support the engine, the fan comes on, high speed. I got the temp for that switch set nicely; it comes on for long highway upgrades in summer, or if I idle it without using the brake. Otherwise it rarely activates.
Why I didn't use an upper (hot) hose switch -
I tried various temp switches in the upper (hot) radiator hose before going to the lower hose solution. In the upper hose, all switches would come on at highway speeds because the water there was already hotter than it should be (because it needs cooling). When I tried an upper hose switch at a high enough temp so it wouldn't come on from normal highway cruising, it also didn't help much in idling situations (stayed off too long), due to being set for too high a temp. Eventually of course it would come on but the temp gauge was rising by that point - which is what I didn't want happening.
Bruckpick, what an awesome idea. Are you still using the same type of a system, and would this work with the regular fan? What kind of temp switch did you add to the lower return hose?
conversion, electric, fan
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Electric vs. belt driven cooling fan Gregte EcoModding Central 63 06-18-2013 06:42 AM
AC Dodge Neon Electric Conversion Videos bennelson Fossil Fuel Free 57 10-24-2011 11:25 PM
b2000 electric fan conversion wmwinfield EcoModding Central 3 05-25-2009 10:19 AM
Extreme Electric Motorcycle conversion for Publicity/Charity bennelson Motorcycles / Scooters 5 11-18-2008 04:09 PM
