Old 02-21-2014, 10:14 PM   #1 (permalink)
dlb
how much difference did MPGuino or vacuum gauge make for you?
i've been on the fence about installing either a vacuum gauge or mpguino in my '90 4wd corolla wagon for quite a while. been giving it more thought lately and wanted to know what sort of real life returns people have seen. for example, what did you average before and after installing it? did it help you adjust your driving habits?
also, i see the FAQ says the mpguino is much more useful than a vacuum gauge but i'm curious about how people feel about one versus the other. is the mpguino really that much better? i am used to carbs so i have a real soft spot for vacuum-related stuff. also, the mpguino is about 3x the cost of a vacuum gauge so i'd like to know if it's really 3x better.
sorry if this is a common question around here. i did a search but couldn't find quite the info i am looking for.
Old 02-21-2014, 11:08 PM   #2 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
I like the MPGuino. In fact, I liked it so much I made a bunch of improvements to make even more useful. I've got one installed in the Karen-Mobile, which is a real neat trick - considering that people owning such a car would generally go with a ScanGauge II or UltraGauge. Planning to install one in my Caravan soon, as soon as I can figure out how and where to take the vehicle speed signal.
Old 02-21-2014, 11:18 PM   #3 (permalink)
dlb
thanks, t vago. did you keep track of your mileage before adding an mpguino? i wonder how much difference it has made to your driving habits and fuel economy.
Old 02-22-2014, 07:31 AM   #4 (permalink)
Southern Squidbillie
It makes a difference, it works and it's fun!
i like measuring manifold pressure, aka vacuum, with a big fat analog gauge. It's quick and easy--put a tee in a line coming off the throttle body and run a hose to the dash and it's working.
i drive a bigass van that got 14 mpg for years and years before i got saved. After i got converted to the ecomod religion my mileage is closer to 17 mpg using all the tricks: pulse and glide, coasting in neutral, staying off the brakes, and quickly accelerating with high load as indicated by the vacuum gauge.
i don't always accelerate, but when i do i drink dosx... i make sure the engine is pulling hard at or near it's most fuel efficient region (i.e high manifold pressure = low vacuum).
When driving i don't need to know or read any numbers in real-time, just look at the needle and adjust the throttle such that it's either floating up in the high vac, or i bury that thang down low when under load.
Old 02-22-2014, 07:31 PM   #5 (permalink)
betasniper's Avatar
Red - '01 Honda Insight CVT
Gen-1 Insights
House of Tudor
90 day: 59.17 mpg (US)
Civic Hybrid - '12 Honda Civic Hybrid
Bahamut - '18 Chevrolet Volt LT
Team Volt
Plug-in Hybrids
My Best tank without the vacuum gauge was 34.56MPG (added bay pan) and second full tank using vacuum gauge was 36.12MPG (without bay pan still from changing oil, smog, etc) and I could still probably fine tune my use. That is a 4.5% increase. I accelerate at 5"hg vac at 2~2.5k rpm thanks to BSFC Chart.
: Brothers
: Dad's
Old 02-22-2014, 10:31 PM   #6 (permalink)
MPGuino Supporter
t vago's Avatar
I can't say that it helped a whole bunch, as I had already fine-tuned my driving habits prior to installing my MPGuino. I rather installed it to see the effects of hardware modifications to fuel economy. For instance, I could measure about a 5.5% increase in fuel economy due to installing aero wheel covers, and I can see an improvement in fuel economy whenever my EGR valve opens up. It's rather interesting to see my UltraGauge and my MPGuino track each other when the EGR valve remains closed, but see up to 15% difference when it opens up. The MPGuino, which actually measures fuel pulses, is more accurate.
Old 02-23-2014, 07:29 AM   #7 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
+1 The Best part about MPGuino is it really is close to real time, my SG2 is really laggy by comparison (yes it's set to 'Fast' comm). After getting used to 'Guino the SG2 is only slightly better than OE FE instumention.
I can't say it's made a big difference to my number as I've already had the techniques mastered, it mostly reaffirms if what I've been doing was right or not. The fuel log doesn't have any real blip when instumentation went in, because in the summer heat A/C use is the biggest factor (3l/100km!) for me.
The real gains can be made with instant feedback urging you to keep up the good work, or to try harder FE instrumentation far outshines a vacuum gauge in this regard.
Old 02-23-2014, 09:12 AM   #8 (permalink)
The analog manifold pressure gauge (vacuum) actually provides instant feedback sooner and quicker than the digitical stuff can, since the ECU must read airflow/massflow/pressure to calculate injection pulsewidth, then the instrumentation must read the output pulsewidth and engine rpm in order to calculate and display FE.
Old 02-23-2014, 04:00 PM   #9 (permalink)
...beats walking...
Technically true, but functionally & realistically a "draw."
Why? Because the movement of air pressure (vacuum) is relatively much SLOWER (millisecond) than the speed of electrons (microsecond)...even though those electrons have to functionally navigate the physical distances (and timing gates) between the sensor, computer, OBD-II CAN-bus, and lastly the SGII or UG.
Thus, my bet is on the electron over the physically moving bourdon-tube needle for pure "speed."
Old 02-25-2014, 01:19 PM   #10 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
Never really used a Vac gauge, but with an Ultragauge for instant fuel economy I went from a consistant 38 up to a consistent 42mpg on a 99 escort. I was already fairly good at the hypermiling thing from my previous experience with my civic and an MPGuino.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
