Old 01-30-2010, 08:14 PM   #1 (permalink)
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
energen 5
I am looking for a belt driven motor-generator that I can put on a Toyora Yaris, as a launch assist. The only info so far is that Delphi Automotive Systems of Troy Michigan have a energen 5 for 12 volt system and energen 10 for 42 volt systems. The google search brings up more trash than I care to wade through, so I could use some help if some one has gone down this road before me. What I have in mind is to us this system for better city milage and maybe tiny solar assist on bright sunny days on the highway. I am in the day dreaming phase...
Redyaris
Old 01-31-2010, 12:18 PM   #2 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
have you looked in to using an Etek motor with regen controller? you are most likely going to need a higher voltage battery pack, then a DC/DC converter to give you 12v for lights and I would say a 12v battery to act as a buffer to keep the dc/dc converter from being over loaded.
Old 01-31-2010, 10:26 PM   #3 (permalink)
Motorcycle
Motorcycle
I just looked at some of the posts relating to etek motors and am intimidated by the complexity. What I was day dreaming about was very small oportunistic use of solar cells mounted on the car to add a small amount of drive force, to save some fuel. I should have known that if it was easy others would have done it by now. I will keep looking...
Old 01-31-2010, 10:40 PM   #4 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Mazda Protege DX
90 day: 46.42 mpg (US)
Read up about the alternator delete options. Deleting the alternator will save a few HP. Then add a deep cycle battery and a solar panel on dash/rear window. Lots of people have talked about it here and some have measured power/mpg gain without alternator.
Old 02-01-2010, 08:11 PM   #5 (permalink)
Motorcycle
Motorcycle
Just got email that Dephi automotive has been sold to Delco-Remy and I have emailed them to find out more info on energen 5...?
