Old 11-04-2009, 05:38 PM   #1 (permalink)
Stickers - '91 Ford Tempo GL
Send a message via AIM to Hermie Send a message via MSN to Hermie Send a message via Yahoo to Hermie
Pulse and Glide with an auto trans
I was curious- Is it mechanically safe to pulse and glide in a non-hybrid, automatic transmission car?
Will going from Neutral to Drive at speed harm anything, or re-engaging into gear at speed do any damage to the transmission?
Old 11-04-2009, 06:32 PM   #2 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I EOC in my van, so does orange4boy. Neither of us have seen any problems, and I go much further than he claims to.
In fact, I've gone up to 3 miles at 60 MPH in neutral w/ the engine off.
When you're at speed, you can put the transmission in neutral, but every time I tried something like that, I didn't really find any gains, because the same places that I put the engine in neutral are the places I'd normally be letting off the accelerator anyway, which meant that in most cases, the engine was basically at high idle, not loaded, so fuel savings were nil.
EOC, I like to think I'm seeing an increase, but I'm coasting down more than a few MPH before starting the engine, as well. I don't do too much driving where I'm going less than 45MPH, so my gains are limited by speed and aerodynamics. In town, you can coast alot further per MPH lost on average, so you may see larger gains than I would.
Old 11-04-2009, 07:17 PM   #3 (permalink)
Driving the TurboWeasel
I can see small gains on the highway by putting it in N going down large hills steep enough to maintain speed down. It's good for 0.5-1 mpg with my car. Letting my foot off the gas is almost as good.
2012 Chevrolet Cruze Eco 6MT
Old 11-05-2009, 12:46 PM   #4 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Depends on the transmission. Mine don't re-engage very nicely at anything above 25 mph. Some other vehicle transmissions it does it just fine.
Winter daily driver, parked most days right now
Summer daily driver
Old 11-05-2009, 12:57 PM   #5 (permalink)
White 4Runner - '98 Toyota 4Runner SR5
90 day: 23.21 mpg (US)
Grey Jetta TDI - '11 VW Jetta
90 day: 39.17 mpg (US)
My 4Runner goes in and out of N smoothly at highway speeds.
Old 11-05-2009, 03:09 PM   #6 (permalink)
In other words, not really enough to make a difference or outweigh the risk of going past N and into R, which will pretty much kill the car. Alrighty, thanks! ^^
Old 11-05-2009, 04:19 PM   #7 (permalink)
If your selector allows you to go past neutral, then no not worth the risk. In my car I don't need to push the button to go from drive to neutral and it will not allow me to go past either one without pushing the button.
Old 11-05-2009, 08:34 PM   #8 (permalink)
You have a floor shifter in the Tempo, right? You should be able to push up from D to N without being able to get into R at all, as long as you don't push the button.
My Candaian Topaz Sport was an auto 2.3 HSC until I blew the torque converter, then I swpaped it out for a 1.9 manual from an Escort Pony.
Old 11-05-2009, 10:30 PM   #9 (permalink)
90 day: 51.82 mpg (US)
Depends if you're talking about killing the engine in the glide or not. Most automatic transmissions aren't designed to coast in N without the engine running (lubrication issues).
Old 11-05-2009, 10:44 PM   #10 (permalink)
Darin -
This is one point that I would have agreed on several months ago, but now, I find that it's more than likely a misconception. I've been EOC'ing my Caravan for a little while now, literally for miles at a time, and have seen no problems in the transmission. I'll know for sure once I take Cara off the road, because I'll drain the fluid and drop the pan to check for problems in the trans before selling it, but I don't foresee any issues.
The thing about this, is that the lubricant in the bearings will remain there for awhile... it's not just going to let them dry out instantly if you shut the engine off. Because of this, I can't imagine another reason why you couldn't put the transmission in neutral and coast for a few hundred feet up to a stop sign or red light, or the like.
The relatively short distances that you can coast while in P&G or the like are almost guaranteed to be far under the manufacturer's recommended tow distance (read owner's manual) and speed, but almost all vehicles can be towed for a short distance at low speeds before damage is really even a consideration.
I'm not openly saying that it won't hurt anything, but in my (limited) experience, it's safe.
Pulse & Glide on Hills mush3gan Hypermiling / EcoDriver's Ed 7 07-13-2013 01:20 PM
Pulse and Glide on the Honda CRX SVOboy Hypermiling / EcoDriver's Ed 4 05-09-2009 12:19 AM
Pulse & Glide question Christ Hypermiling / EcoDriver's Ed 22 12-18-2008 01:53 PM
Old School hypermiler PULSE AND GLIDE Dragonova Hypermiling / EcoDriver's Ed 13 07-08-2008 07:26 PM
Re-attempting Pulse and Glide (with an automatic) Lazarus Hypermiling / EcoDriver's Ed 6 12-11-2007 08:06 PM
