Engine Compartment Venting
Hi,
Currently, I am venting the engine compartment through gill slot openings in the belly pan. This is making lot of turbulence under the car, it's like having a window open. I am considering venting though the front wheel wells, where the air is already disturbed. Anybody have any thoughts or comments on engine compartment venting? |
According to Hucho, the very best arrangement is to vent into the area on top of the hood. Venting into the wheel wells and into the underneath are equal and are half as good Cd wise, according to his book.
Venting under the car could be marginally better if there's one of those higher diffusers. |
Pull out the seal for the hood at the base of the windshield...
Venting on top would put a lot of dirty air over the car body. Im going to try venting into the wheel wells and close off the openings in the under body belly pan and shoot a tuft video again.
it is sealed, read the first post! |
Try reading this paper "Interference Effects of Cooling Air-Flows with External Aerodynamics" . It covers how engine compartment cooling effects overall drag.
http://tech.jsae.or.jp/ijae/download...x?pno=20114635 Edit: I think you want to keep your under tray gill slits :) |
Interesting paper.
The red looks better than the blue. I don't know why the square back and notch back are so different, very strange. The blue defiantly had more air flowing, because of the bigger opening. I don't think this paper applies completely, since my wheel wells are covered the air can not escape through the sides, but must exit under the body through the tire clearance holes in the belly pan.., my grill opening is minimal, I will be keeping most of the blue closed. |
well you might consider you could be doing more harm than good. On the other hand the biggest difference it made was 0.004 in Cd over or under the base line.
I would like to keep the flow smoother under the car to try to get better pressure recovery on the boat tail bottom surface.
The question is does smother flow on the under side of the boat tail really going to get a net gain by disrupting air flow some where else?
What I think you are trying to say is that flow around the wheels is already disrupted and that a bigger disruption there won't matter. In this paper they show for both the notch back and the square back that isn't the case as drag increased when they blocked off the transmission tunnel. If this is the case for your car I can't say and I don't think any one else will be able to unless they have a wind tunnel that can measure Cd to the 3 digit after the decimal point. |
My car doesn't have a transmission tunnel.
"None of our men are 'experts.' We have most unfortunately found it necessary to get rid of a man as soon as he thinks himself an expert because no one ever considers himself expert if he really knows his job. A man who knows a job sees so much more to be done than he has done, that he is always pressing forward and never gives up an instant of thought to how good and how efficient he is. Thinking always ahead, thinking always of trying to do more, brings a state of mind in which nothing is impossible. The moment one gets into the 'expert' state of mind a great number of things become impossible.” " ... Henry Ford |
Over the hood. Will help reduce lift from air under the car.
Very interesting study. Slightly at odds with Buchheim, et. al., but interest anyway.
One take away was that the aero drag from cooling is linear with the amount of cooling air. Ecomodders have been proving that for a while;) |
Maybe you could consider NACA vents on your belly pan, those should reduce the turbulences under the car siginificantly, comparing to grill like vents you've mentioned in a first post.
NACA vents are low drag intake vents, not meant for exhaust.
http://en.wikipedia.org/wiki/NACA_duct I am considering streamlining the engine compartment, ducting the flow so it expands from the slit in the bumper to the radiator (diffuser) and then narrowing again to the exit and try to match the external flow velocity with minimum turbulence. I don't know if it can be done in practice, but I had something similar on an earlier saturn and that car would blow leaves out the back. I'll post progress on sc1 aeromods thread. I ordered more rivets, hopfully they will arrive today. |
Check out google for "reverse NACA duct"
http://i108.photobucket.com/albums/n...E/DSC_3962.jpg Bring back the NACA duct..... - PistonHeads NACA can work both ways. I've seen NACA-like outlet working as an exhaust tip, but can't find a photo right now to link it. It was just build as reverse of NACA inlet. So it was wider at the very end of the outlet and it was tapering to the front and the actual exhaust pipe. I'm hoping you get the idea from my description. |
Sorry, but show me one on an airplane that's mounted backwards..
Its hard to believe that a notchback will suck that much more air out of the front wheel well. Maybe the notchback has lower overall drag and thus the open wheel well adds a proportionally larger amount. |
Cd of Notchback with moving ground simulation = 0.277 Cd of SquareBack/Estate with out moving ground simulation = 0.318 Cd of SquareBack/Estate with moving ground simulation = 0.319 http://delphi.com/pdf/techpapers/2012-01-0168.pdf |
Cobra daytona coupe or ford GT both with hood venting and pretty darn fast daytona coupe was reported going over 190 on the british M1 highway i think they called it and reportedly was the reason the road got a speed limit! so if you can pick up almost 30 mph with the same engine combo , the aero cant be that bad,
The no compromise Lotus Elise uses top venting. Not sure where they pick up their cabin air intake. I've toyed with trying the arrangement on my "test" Insight. I think I see a way to get clean cabin air through the fenders with NACA ducts. Big project and not sure when/if it gets done. |
Book
If you can locate a copy of Paul Van Valkenburgh's book,Race Car Engineering. He has a section on measuring pressures on the outside of a cars body which would be invaluable,short of a wind tunnel,for siting cooling system exits.
For a 'clean-sheet' race car design you could slect one of the off-the-shelf designs depicted by Hucho or Korff.For a production vehicle you're going to be challenged because of the existing underhood architecture. Professor Alberto Morelli probably spent millions of dollars perfecting the outlets on the CNR 'banana' car of 1978. You could not have chosen a more difficult project to take on. This is truly a case-specific-basis only type proposition.With the variety of vehicles out there,there won't be any one-size-fits-all solution.:o |
My RS front bumper on my Focus uses these functional vents..
http://i102.photobucket.com/albums/m...0505-00466.jpg There is baffles behind the rad to help duct out the air towards these side vents... |
2012 Fiesta wheel well vents
I think that the outlet on the hood top has to be farther forward. It would probably be tricky to select the fore/aft position for such a top exit. One would need to look at the local pressures as aerohead suggested. And, Hucho suggests that the under hood vent work must be smooth to get any advantage. That requirement alone is a big stumpling stone on most front engine cars as there is a lot of stuff in the way:( I wouldn't do something just at random. It is a tricky problem even for those who want to live with the disadvantages. I like to do aeromods, but I've been slow to act on this one. |
In the cold light of day, it wasn't the best idea I ever had. I was thinking of an external duct on top of the hood, like a snorkel, to separate the vented air from the cabin intake. It would probably interfere with the wipers.
Depending on where the optimally-positioned vent and the intakes are, maybe vertical fences on the back of the hood would suffice. |
I think I an going to put the gill slits back on.
67 Mustang had vents right behind the front edge of the hood for cooling , they help a lot over earlier no venting models, might be a problem with water entering if further back also helped to kill some of the lift those cars were famous for.
I believe the idea is to vent it to a low pessure area to better fill the void. Is there any way you can get it vented behind the car? Maybe by running some sort of vent inside your already made belly pan to the back of the car? Maybe 2 vents running along the exhaust. Hm.. Would that put too much pressure on your belly pan? Can someone comment on my ideas please.
Testing showed no center turbulence improvement with venting through tire clearance holes.
I believe the famous shneider cup racing airplanes of the thirties , at least some of them used the skin of the plane and evaporative cooling or something along those lines, I think a vent right behind the radiator with maybe a sheild for rain would probably be the best, like and old fashioned cowl vent as used on fifties cars only right behind the rear edge of the radiator or close to it, the air here is going up and pulling a vacumn on the front of the hood on most cars I would think and this allows a bit of air to fill that and kill some lift as well.
