Old 11-15-2012, 09:33 AM   #151 (permalink)
TheCav - '04 Chevy Cavalier LS
WOW! I have an 04 Cavalier almost same vehicle as you. Good to see that mileage is obtainable with just aero mods.
Thanx for the good info.
Old 11-16-2012, 03:55 PM   #152 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Oldmobile aerotech longtail
I am going to clean up this mess under the car, sc1 aeromod underbody:
The yellow chloroplast had become brittle in 3 years. The white is still good after 7 years. The two engine cooing vents are shown. Some of the belly pan on the left was removed for gas line cooling. Sticks and stalks get stuck in the vents when reversing in the field. You can see where its melted at the converter.
... New coroplast in place, engine vented to inside of front tires, in the clearance holes. Bungees safely underneath.
- Tony
The Following 3 Users Say Thank You to arcosine For This Useful Post:
aerohead (11-17-2012), Cd (11-17-2012), Weather Spotter (11-20-2012)
Old 11-17-2012, 11:44 AM   #153 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Can you post a side view image of the full car ?
Also, when are you going to test the top and sides of the 'tail ?
Old 11-17-2012, 06:13 PM   #154 (permalink)
I just found the thread.
It looks like the tail does a convex to concave transition to accommodate the taillights. I like that.
Cut that Oldmobile aerotech longtail off at the rear axle centerline and you have the design of the car in my Profile Picture. It would have a pontoon around the engine case with the cylinders and heads in the airflow. The lack of boattail was due to my thinking in the 1990s. How much weight would you estimate you added so far from the center of gravity?
Old 11-18-2012, 08:35 AM   #155 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
Ready for the fox hunt.
Boat tail Weight:
40' tubing (could have gotten away with 30') 2.9 lbs each
3 panels coroplast (probably 2.3 sheets on the tail, rest scrap) 4 lbs each
9' steel wire 1/8 dia (maybe not needed) .5 lb
36' 14 gauge wire (could have used 20' of 16 gauge) .5
4 trailer lights .5
2.9*40+4*2.3+.5*3= 23 lbs
Cd: picture
Video of tuff testing didn't turn out well... uploading to Youtube
http://youtu.be/Qrjo2pYyquQ
http://youtu.be/OQOjC3bGwAM
- Tony
The Following 4 Users Say Thank You to arcosine For This Useful Post:
aerohead (11-19-2012), Cd (11-18-2012), freebeard (11-19-2012), Weather Spotter (11-20-2012)
Old 11-18-2012, 06:23 PM   #156 (permalink)
Cd
Ultimate Fail
Cd's Avatar
That looks great.
I'm sure the car slips through the wind like a hot knife through butter.
( Looks like the tufts should have been black so you could see them against the silver.)
P.S. Your Avatar needs an update
Old 11-20-2012, 08:02 PM   #157 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
thanks for the tuft video, I know you know its bad, but I cannot see the tufts enough to comment on flow.
you said you have a magnet mount for your ham antenna, can you mount a camera on that and put that on your car/ chase car?
we need to have another boat tail meet up/ induction ceremony. you and Sven7 need proper group shots with the rest of us
Old 11-20-2012, 08:33 PM   #158 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
I'm open for black friday. we could pick out a nice car for Sven.
http://stlouis.craigslist.org/cto/3422553384.html
- Tony
Old 11-21-2012, 04:02 PM   #159 (permalink)
Wiki Mod
thats a bit soon for a meet up. how about some time in the spring so sven7 can get a new car and build a tail for it.
Old 11-21-2012, 04:44 PM   #160 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
wow that car says XFI on it .. for $500
http://images.craigslist.org/3E73I63...42f04b156e.jpg
2000 Insight MT 106K Citrus A/C
saturn
