An engineer mods Porsche 911
Here is a mechanical engineer who explains his chassis mods simply, executes them himself, and then measures their effects.
Here he is seam welding and measuring the effect A/B: https://m.youtube.com/watch?v=RfDPUD-RhMM Here he is describing other chassis mods: https://m.youtube.com/watch?v=T0bOIdr1sTA He should get more attention on the YouTube. |
Is it misleading to say you are an engineer if you've never had an engineering job, but have a degree?
You find some fault with his measurements of the 911's chassis stiffness? |
No. I graduate in December and wanted to know if I could call myself an engineer even though I haven't had a engineering postition yet. :D
When they do give you your degree, take your feet clear off the ground or load up barbell weights. Otherwise is to put your thumb on the scales.
The 1920s Briggs & Stratton Buckboard Flyer had solid axles and all chassis flex. |
To be fair, he apologizes profusely.
Congrats (a little premature) on your degree, M_a_t_t ! |
I dunno, there's all sorts of hair splitting over in Aerodynamics
