Old 06-29-2010, 01:01 PM   #1 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Volt may become a parallel hybrid
Volt shock - Telegraph
Until now the car's hybrid driveline has operated with wholly all-electric drive, but poor high-speed performance and power-generation losses are forcing GM to consider powering the Volt/Ampera directly from its petrol engine at high speeds (read our Vauxhall Ampera prototype review). The move would be possible without major engineering as the planetary twin-clutch transmission already has a direct mechanical link between the engine and wheels.
This is good news for people who are interested in maximum gas-mode fuel economy. Powering the wheels through a transmission is the most efficient use of a range extender. The range extender should only need to operate at highway speeds, so you wouldn't need many gear ratios, and the engine could be kept near peak BSFC with the electric motor being used to add or subtract power if needed.
It does create some questions about how Chevrolet will differentiate the Volt from the Prius, how much of a development delay this change would create, and why the previous version had a direct mechanical link between engine and wheels if it was intended to be a series hybrid from the get-go.
The Following User Says Thank You to RobertSmalls For This Useful Post:
Frank Lee (06-29-2010)
Old 06-29-2010, 01:54 PM   #2 (permalink)
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
It's about time they got their heads out of their butts.
Old 06-29-2010, 01:57 PM   #3 (permalink)
They could also get better efficiency by charging the battery and running the ICE at a constant RPM -- something you cannot do with an ICE driving the wheels.
Old 06-29-2010, 01:57 PM   #4 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
RobertSmalls -
When the Volt was announced, I thought, okay the Volt is incorporating the "Prius Plug-In" retrofit concept, and now it's becoming even more like a Prius.
Looks like the Autobahn influenced the decision :
General Motors is about to dramatically re-engineer its Volt/Ampera extended-range battery car to better suit it to high-speed European use.
During the car's development, GM increased the capacity of the petrol engine from one to 1.4 litres to maintain the charging performance, but the single-speed electric motor starts to run out of torque at speeds above 50mph, affecting motorway and overtaking performance.
CarloSW2
American Solar Energy Society
Old 06-29-2010, 02:00 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Neil -
That's what I thought, but in one of our previous Volt threads I posted a tidbit where the Volt engineers abandoned constant RPM in favor of a "range" of variable RPM/load settings.
CarloSW2
Old 06-29-2010, 02:01 PM   #6 (permalink)
Patrick's Avatar
I think the Prius can do it with the ICE driving the wheels, due to the planetary gearbox.
Old 06-29-2010, 09:44 PM   #7 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
Just one more way to push the Volt further into the future.
Old 06-30-2010, 12:03 AM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Straight series sucks, guess they had to find out the hard way.
Old 06-30-2010, 10:24 AM   #9 (permalink)
dcb
needs more cowbell
dcb's Avatar
I think it is very telling though.
According to that article, the 71hp hp gas motor is struggling to keep the car going 50mph
the 149 hp electric motor on batteries can go at least 100mph
it should take no more than 1/4 of 149 hp to go 50mph
so of the 71hp in the gas motor, no more than 37 hp make it to the wheels via the "electronic transmission"
the transmission of power in this series configuration is %52 efficient at best.
It certainly doesn't add up, if this is the case, how did they ever figure on 50mpg in range extended mode? Something isn't right here.
Old 06-30-2010, 10:52 AM   #10 (permalink)
...beats walking...
...sounds to me like an automotive shell game: "electro-MPG" under one shell, "gas-MPG" under another...shuffle sufficiently and dazzle the audience into believing they're BOTH the same MPG result.
"The Volt" May BE SCRAPPED!- NEVER BUILT!! Jammer Hybrids 460 08-22-2013 07:08 PM
--- 48 volt golf cart motor --- for diy hybrid possible? basslover911 Hybrids 19 07-06-2010 06:46 AM
Solar charging two 12 volt batteries (parallel)... SKIN Off-Topic Tech 5 09-04-2009 03:58 PM
chevy volt hybrid dcb Hybrids 8 08-10-2009 11:46 AM
News: GM planning dedicated high efficiency hybrid (in addition to the Volt) MetroMPG Hybrids 17 07-16-2009 10:20 PM
