Old 04-05-2017, 01:34 PM   #1 (permalink)
Eco Sol
Shortie771's Avatar
EPA Testing Procedures
While reading an incredible long article (more like a book) I came across a page that has some interesting information where EPA numbers come from and figured I would share it here.
Car Bibles : The Fuel and Engine
According to this, we should all feel much better about our % over EPA numbers. Especially if you own a vehicle build before 2008 because our true EPA numbers should be much lower then they are, once all factors are considered. So my REAL EPA (due to inaccurate testing) should be closer to 24.4mpg combined, instead of 28mpg. If this is true then the 41.6% over EPA I got on my last tank (personal best btw) would actually be 54.6% over EPA if adjusted to today's EPA standards.
EPA TESTING PROCEDURES
Congress and car company lobbyists required the EPA to measure mpg figures using the following simulated real world conditions in a lab. That's right - EPA testing happens on a dyno in a lab, not on the open road.
Average highway speed : 49mph
Maximum highway speed : 60mph
Temperature : 75°F
No rapid acceleration
No air conditioning
No passengers
No rough roads
No hills
No wind
No low tyre pressures
No ethanol in gas
The first problem is the last point : no ethanol in gas. In America, it's almost impossible to buy zero-ethanol petrol - it's all E-10 (see E10 elsewhere) so you're already going to be down 5% on the EPA figures even if you could meet all the other requirements.
I also learned that the EPA ratings for European cars are higher (probably due to US NOx standards) meaning if you own a European car you probably won't get as much over EPA (if you do, you're awesome!) as you would with the same car in the US. The bar is already set higher, leaving less room for improvement.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
Old 04-05-2017, 03:22 PM   #2 (permalink)
Dark Egg - '12 VW Touraeg
Except they arbitrarily just reduce the actual test results a certain percentage to take those things into account. They also add stop and go to the highway test. (I don't stop on the highway until it's time to get gas or pee). See I'm the other way around, I want a real, long distance, highway steady state MPG test. Basically what a car or truck gets at a constant 65mph. Hills may hurt on the way up but they sure are nice on the way down. Technically they can actually help by basically be a forced pulse and glide.
Overall the rating is good, many people get worse MPG but the few here show they could actually beat the numbers with some thought and attention. They do need to fix the manual transmission forced high rpm shifting penalty. If you want to be the cool guy beating the EPA rating by the most get a manual because they make the testers drive like a moron with the shift points.
Old 04-13-2017, 09:45 PM   #3 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
You only need to look at my sig to see how wildly variable EPA/NEDC numbers can be, same driver, different cars, almost a 100% spread
Old 04-13-2017, 10:03 PM   #4 (permalink)
Isn't their highway testing speed kind of unrealistic too?
Old 04-13-2017, 10:22 PM   #5 (permalink)
Eco Sol
Shortie771's Avatar
Completely unrealistic! Most highway speeds around me are 75mph. Heck, the back road I live off of has a speed limit of 60mph.
CR-Z Current Mods:
Max Sidewall PSI
Old 04-14-2017, 01:58 AM   #6 (permalink)
SUVcruiser - '07 Ssangyong Kyron 2.0 XDI
90 day: 42.55 mpg (US)
SUVcruiser year 2017 - '07 Ssangyong Kyron 2.0XDI
Hybridcruiser 2023 - '13 Volvo V60 D6 AWD
90 day: 123.84 mpg (US)
So does this mean that i aim awesome
Drive smart, save fuel, save money, spare the enviroment
But keep having fun!
I can drift
Previous car. SUV. From 2011+ 10l/100km to 2017 5,516l/100km.
2017 without holiday: 5,397l/100km
EPA Rated average: 8,1l/100km
Current ride: plug in 285hp hybrid
EPA Rated average: 2,8l/100km
Old 04-14-2017, 02:35 AM   #7 (permalink)
Eco Sol
Shortie771's Avatar
Precisely! Way to go
CR-Z Current Mods:
Max Sidewall PSI
