Old 06-12-2008, 11:20 PM   #21 (permalink)
White 07 Civic - '07 Honda Civic LX
90 day: 38.87 mpg (US)
I used a saw, and a surform. If it makes any difference, and I think it does. I used the spray foam "large areas" It seemed to cure much softer than the other stuff. It does expand much more though. I am thinking that on my next attempt I will fill the large areas with blocks of eps or xps foam, then fill in the gaps with spray foam. I was also thinking about building a lattice with very thin pieces of wood then draping fiberglass over that. Following that I would cover with bondo, and sand it down until parts of the lattice were exposed.
Old 06-12-2008, 11:47 PM   #22 (permalink)
NewBlue - '07 Honda Civic EX
90 day: 38.13 mpg (US)
The Better Half - '97 Ford Ranger XLT
90 day: 25.84 mpg (US)
Those fog lamp holes are annoying, have you done any testing with them covered yet? I am doing a couple test runs next week until I can get my permanent covers made, anybody know where to get materials to glass over the foam? Home Depot have it?
2007 Honda Civic Ex
Second Goal = 50mpg
First goal = 40mpg Goal Achieved 3 tank average over 40mpg
Starting point 30mpg ready...... GO.
Old 06-12-2008, 11:53 PM   #23 (permalink)
pontiac trans am - '00 pontiac firebird trans am
jeep 1 - '02 jeep wrangler
90 day: 16.76 mpg (US)
jeep 2 - '07 jeep wrangler x
90 day: 19.39 mpg (US)
Toyota - '09 Toyota Corolla lx
you can get bondo brand fiberglass materials from wal-mart, auto parts stores, and home depot., i havent tested yet but i dislike them so much that i really dont care how little of an improvement i see so long as it looks better
Old 06-13-2008, 12:51 AM   #24 (permalink)
Johnpr, Also if you haven't already look under the rear bumper on the drivers side there is a HUGE parachute under there which would be do well to be covered up and became one of my priorities when I saw it.
2007 Honda Civic Ex
Second Goal = 50mpg
Old 06-13-2008, 12:58 AM   #25 (permalink)
yep i saw that also, i have been debating on how i want to tackle that area. if i have time i will take measurements and that will help me decide on a material. have you thought about how you will mount a panel near the rear axle, i was thinking about welding some tabs on there. i will take some pics though and figure something out
Old 06-13-2008, 07:42 AM   #26 (permalink)
I've noticed that parachute as well. That is going to be the next project after the grill block. Were you guys thinking of using pour foam to fill it in?
Old 06-13-2008, 09:11 AM   #27 (permalink)
not in the rear, i think with that amount of foam it would be a considerable amount of weight, i am either going to use a plastic or metal sheet, whichever is cheeper for me.
Old 06-13-2008, 09:13 AM   #28 (permalink)
I am going to look into getting a sheet of coroplast for that sheet and test it out, there aren't any high temp parts in the area so anything that can withstand some rock hits would work well.
2007 Honda Civic Ex
Second Goal = 50mpg
Old 06-13-2008, 10:18 AM   #29 (permalink)
3wheeled's Avatar
My kids and I have been building a 3-wheel car from the ground up. We have built the body out of urethane boards purchased from a local lumber yard. Glued the panels together with the spray urethane foam (Home Depot) and then covered both sides of the body with 2 layers of fiberglass and polyester resin. It is quite a job but a lot of fun for sure! Here are some pictures over the years...
http://picasaweb.google.com/stinger3wheel/Stinger
Laziness: Resting before you're tired!!
Old 06-13-2008, 11:52 AM   #30 (permalink)
TheDon's Avatar
Pepper - '87 Mercedes Benz 300D
90 day: 30.42 mpg (US)
those are some massive wheels
I found another advantage to driving an ultra-low Cd car basjoos Aerodynamics 26 08-25-2012 02:15 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
My First Electric car Experience WaxyChicken The Lounge 8 09-05-2008 08:46 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
