Old 12-22-2009, 07:59 PM   #1 (permalink)
Cycling more to drive les
White 'rolla - '05 Toyota Corolla LE
90 day: 44.39 mpg (US)
Send a message via AIM to Chalupa102
Exhaust header: help or hurt f/e
A while back when i was into quicker acceleration i installed an exhaust header (4-1 style) in place of the stock manifold. Since hypermiling i almost never exceed 2500rpms, so clearly i don't care how fast my car accelerates now. There's a person with a Corolla who is willing to buy my header and give me his stock manifold. Do u guys think the header helps or hurts f/e, and should i do the swap?
Corolla aeromods thread:
http://ecomodder.com/forum/showthrea...ead-11210.html
Old 12-23-2009, 02:12 AM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
your getting pretty decent mpg right now....
I had a 66 mustang back in college) with a 200ci inline 6 cyl. I intalled headers and dual exhaust but used 1 3/4 pipe to provide some backpresure. going back and forth to shool on the freeway it worked great. When I graduated, I went to a single pipe and single muffler to get the backpresure up even more. I was doing mainly intown driving.
moral of the story is that you need some backpresure for the engine to work effecveintly....in my opinion.
Old 12-23-2009, 06:51 AM   #3 (permalink)
A properly designed header will improve mileage. Pretty much all aftermarket mufflers are designed to shift your powerband to higher rpms. This of course is the opposite of what we want. So, short of making your own custom header, I'd say it won't help.
Old 12-23-2009, 09:11 AM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I'll just chime in to confirm this. If you want a header to increase FE you need to do custom design keeping in mind troublesome things like resonance blah blah. Seems more effort than it is worth.
Old 12-23-2009, 09:32 AM   #5 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Unfortunately, I have to stick a word in here.
I did two mods in the interest of power to my Civic that also increased efficiency to a point where my economy improved noticeably.
#1 MPFI swap. Started with DPFI, and with my (then) driving style, this wasn't working out well. No torque on the bottom of the revs at all, so I was always revving up to keep the car moving. I seldom used 4th or 5th gear. After the MPFI swap, more low-end, so I used the lower gears more.
#2 eBay header. Yep. $32 shipped, and (no scientific data here) about 3MPG increase. Of course, again, I was also driving much differently then than I do now. Also, there was a marked increase in low-end again, header vs OE exhaust. I did not remove the cat or install an open muffler. I had a thrush turbo muffler on the back, in the OE configuration. Later, I installed a fart can, but left the baffle in it. I never noticed a decrease in torque until I removed the baffle.
Both of these are non-conventional mods in the terms of the way we (the majority of people on this site) drive, but if you don't drive like us, they may make a difference for you.
In all honesty, I'd probably do both mods again, except change my transmission to longer gears to accommodate the increase in torque. This is where I wish I'd kept my Civic and the HF transmission that I sold.
Old 12-23-2009, 09:47 AM   #6 (permalink)
I agree, if the header increases low rpm torque, it will most likely increase mileage.
It has been my experience that most headers are not designed this way though.
Old 12-23-2009, 09:49 AM   #7 (permalink)
I think in the case with the early D-series engines, the OE exhausts were so inefficient at doing their job, and the added scavenging from the header made it run easier on the lower ranges.
Again, never really tested it, though.
Old 12-23-2009, 10:21 AM   #8 (permalink)
Black Beauty - '09 Honda Accord EX-L
90 day: 27.44 mpg (US)
Increasing torque is good. Keep the headers man.
Old 12-23-2009, 10:23 AM   #9 (permalink)
I have a Mopar hot rodding magazine that detailed the same changes to a Dodge Neon. They were able to find an additional 37lbs of torque by doing this to the 2.4L engine. I have since dreamed of this doing this to make a FE NEON.
Old 12-23-2009, 10:40 AM   #10 (permalink)
Dartmouth 2010
SVOboy's Avatar
Can you scan and post this article? Would be interesting
Raising Exhaust 99LeCouch Aerodynamics 13 10-18-2009 05:51 AM
Does Exhaust Noise Play a Role in Fuel Economy? Metallover EcoModding Central 16 07-12-2009 09:47 PM
Civic Vx engine question. stock exhaust manifold vs. stock exhaust manifold vtecn8ive DIY / How-to 3 07-12-2009 01:07 PM
on a jeep 4.0 the intake manifold gets as hot as header they are so close, shield it 95CHERJUST EcoModding Central 5 10-16-2008 04:00 PM
MetroMPG.com mailbag: various questions (final drive, exhaust, underdrive pulleys...) MetroMPG EcoModding Central 0 02-23-2008 08:40 PM
