04-30-2010, 08:39 AM
Civic DFCO Conditions
I remember reading this at one point, but just spent what seemed like forever searching as many different terms as I could to try and find it, to no avail.
Anyone have a link to the conditions that need to be met in a Civic for DFCO? If it matters, my car is a '95 DX.
04-30-2010, 09:06 AM
needs more cowbell
if you have a convenient kill switch (mine is a small microswitch on the gear shifter) you can tell when you are NOT in dfco, as the sound will change when you hit the button and you may notice a faster deceleration.
if you have a mpguino, your instant gph should go to zero and your instant mpg should go to 999999 when in dfco
FYI, I don't think an OBD II open loop indicator necessarily means dfco, could mean any change from closed loop. In fact now that I think about it, the metro would show open loop any time I decelerated in gear, but later monitoring of the injector revealed more specific conditions.
iirc, my metro would not go into dfco unless I was going above 40mph and would drop out of dfco (start burning fuel again) at about 25mph, in top gear.
This might be a good wiki candidate too to "publish" different dfco conditions for different cars
http://ecomodder.com/wiki/index.php/Main_Page
04-30-2010, 09:59 AM
Hypermiler
On my 1996, it has to be in gear, foot off the pedal, and above 1200 rpm. If you try a few coast-downs, you can feel a "surge" when the fuel flow comes back on. Our cars are different generations, sort of, but both have D-series engines.
With a DX, I'm assuming you also, like me, have no tachometer. Note the speed and which gear you're in for the coast-down, and you can calculate the rpm. Example: Max speed in 2nd gear is 62 mph. DFCO shuts down (surges) at 11 mph. Max rpm is 6900. 6900*(11/62) = 1224 rpm.
The Following User Says Thank You to PaleMelanesian For This Useful Post:
04-30-2010, 12:42 PM
I can feel it in the lower gears, but not in the higher... One of the main things that I was wondering about was if it was linked to the brake switch as well. That is part of the reason I was looking for the post, because whatever post I remember reading I almost want to say that it says the DFCO kicks off (or in other words the injectors start again) when the brake is pressed. I did some DFCO last tank but did brake while decelerating in gear (normally I just shift to neutral while braking) and MPG went down... So I was trying to prove (to myself at least) that this was because I was failing to DFCO because I was braking.
Does not apply... I swapped in a tach a while back, but you are correct, it did not have one originally.
Maybe I should just wait and not try to DFCO until I have my MPGuino hooked up (currently started assembling the parts last night I had acquired to build my own "kit").
Just wish I could find the information that I remember reading. I do not remember if it was on here or somewhere else... And hell, for that matter it could have even been for another car (not the Civic) and I just made it up in my mind that it was for the Civic... lol Would not be the first time I remembered something incorrectly.
If I do find it though, I might try and figure out how to add it to the wiki and start a DFCO condition list.
04-30-2010, 02:38 PM
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited 90 day: 13.62 mpg (US)
Also, be aware of this: Even if it stays in DFCO down to 1200, it may not enter DFCO unless you're above 1500 or so.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
04-30-2010, 02:53 PM
Hypermiler
Not true on mine. Engine braking above 1200 rpm, triggers an Open Loop status on the ECU, which indicates DFCO.
I try to avoid dfco. It's more efficient to start an EOC glide earlier, than to burn a little more gas and then bleed it off through any kind of braking. DFCO is braking.
04-30-2010, 04:34 PM
Yeah, but most of the hills that I go down have stop lights at the bottom of them that during my daily commute I would say I get stopped at them 80% of the time. I actually saw a decrease in MPG when I would EOC on my daily commute. If I can DFCO down the hill, it would be great, because more than likely I will have to brake anyway.
But again, that is why I want to know the conditions, because if using the brake causes it to kick out of DFCO, that would be good to know so I could just neutral coast rather than trying to DFCO when it wont.
04-30-2010, 05:10 PM
Hypermiler
Ah, I see. I don't know about using the brakes and whether that cancels the DFCO condition. Sorry.
04-30-2010, 06:54 PM
#9 (permalink)
No big deal... I do not know about it for sure either... lol Thus the reason for this post
Guess I will do some testing when I get my MPGuino up and running. I am beginning to feel like I just made up that post I think I remember... lol
04-30-2010, 08:26 PM
#10 (permalink)
I've never noticed the brakes kill DFCO on any vehicle I've driven.
The Following User Says Thank You to comptiger5000 For This Useful Post:
