EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   External air curtains (https://ecomodder.com/forum/showthread.php/external-air-curtains-38924.html)
JulianEdgar 12-21-2020 03:08 PM
Throttle stop drag tested, tuft tested and pressure tested. The most effective 'simple' modification for measured drag reduction that I have done.
https://www.youtube.com/watch?v=lSN2vQE_WPs
freebeard 12-21-2020 03:47 PM
The best candidate I've seen, from Ecomodding Central. I suggested he search on 'edgarwit':
https://i.gyazo.com/79057290b82dffb3...01cc2a8e68.jpg
https://ecomodder.com/forum/showthre...eas-38904.html
kach22i 12-21-2020 06:04 PM
Awesome.
I appreciate you trying new things and testing them rather than dismissing them as something only large corporations with vast resources and staff of professionals can do.
IRONICK 12-22-2020 04:54 AM
And why does it look so ugly? The modifications must be applied in such a way as to be related to the current design of the car. It's like they're taken from the truck ...
I would have chosen the solution inspired by Mercedes-Benz A-Class/C-Class.
JulianEdgar 12-22-2020 05:12 AM
Well when you do so, you can show us the results.
freebeard 12-22-2020 12:05 PM
And why does it look so ugly? ... It's like they're taken from the truck ...
That's a section of aluminum extrusion. I consider it proof of concept.
IRONICK 12-22-2020 04:09 PM
It is totally useless in this case. An aluminum (or any other material) sheet does the same thing.
JulianEdgar 12-22-2020 04:16 PM
You'll have to show us the results of your testing - this is an interesting area.
Vman455 told me he used sheet metal for external front air curtains and recorded a drag increase on his Prius - but they gave much better stability when passing trucks.
As I say, I'd love to see the results of your tests.
Vman455 12-22-2020 04:39 PM
Yes, this is correct--the sheet metal front ducts by themselves appear to increase drag based on fuel economy testing. But when I compared pressure difference on each side of the car just behind the front wheel arches (at Julian's suggestion--thanks!), I found that the average pressure difference between sides in a 25 mph crosswind was nearly 15% lower with the ducts on. The wing sections seem to be a better solution, and something I'll probably try in the future.
freebeard 12-22-2020 05:08 PM
Can you post a comparison of the two approaches?
I speculate that a flat plate would have critical angle-of-attack and positioning criteria. I further speculate that a curved plate would approach the result of the airfoil section.
I've been thinking about air curtains on a Geo Metro. It looks like I could add a partial diverter on each side (flushed out to the upper bumper) with curved plates capping the void created.
