Old 08-16-2012, 02:21 PM   #1 (permalink)
2013 Leaf to get redesign, ~25% more range & possible lower cost/range version
Looks like there will be some substancial changes done to the 2013 Leaf. It looks like it'll get a 25% increase in range. There is also a possibility of a cheaper version of the Leaf with a reduce range. Japan will be getting it for sure, there is no news of it comming here yet though.
2013 Nissan Leaf: More Range, Cheaper Model, Report Says
Now a report from Japan suggests that Nissan will offer a 2013 Leaf with longer range, as well as a lower-cost model with a smaller battery pack (which could be restricted to sales in that country).
The improvement in usable range is attributed to improved performance from the battery's lithium-ion cells and a more efficient electric motor.
If so, that would put the 2013 Leaf ahead of the Ford Focus Electric (76 miles), Honda Fit EV (82 miles), and Coda Sedan (88 miles) in rated range.
The less expensive 2013 Leaf with lower range may be limited to buyers in Japan, which has different tax subsidies and buyer incentives. Mitsubishi already sells a lower-range model of its i-MiEV electric minicar there.
Old 08-16-2012, 02:47 PM   #2 (permalink)
90 day: 51.82 mpg (US)
Also of note (I added to the thread title :P):
The Sankei report also says that Nissan will "dramatically change the appearance" of the Leaf's design.
Here's hoping they incorporate aerodynamic improvements. The car's current drag coefficient is pretty poor for an EV. Maybe they're already factoring aero optimization into the range increase.
Old 08-16-2012, 02:53 PM   #3 (permalink)
Cd
Ultimate Fail
Cd's Avatar
+1 !
Old 08-16-2012, 06:57 PM   #4 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
God forbid a 1000lb weight loss and aerostreaming
Old 08-16-2012, 11:13 PM   #5 (permalink)
If they can reduce the Cd close to EV1, then they would have a hit on their hands! I hope it looks a bit better, too.
Old 01-09-2013, 09:13 PM   #6 (permalink)
2013 Nissan Leaf likely gets ~14% better range i.e. ~10 miles
A little more information on the 2013 Leaf, being built in Tennessee; along with the batteries and the new motor, too.
2013 US Leaf has improved range, charging speed, and lower price
Range is not yet officially determined, but Nissan says it should be ~14% better, or about 83 miles. The Leaf S will be significantly less expensive (maybe $5K?) but it won't have the new 6.6Kwh charger (though you could add it as an option). The new charger is in the front, which frees ~1.5cu ft of trunk space. The new Cd is allegedly 0.28 vs the 0.29 it was - which is probably due almost entirely to the new more closed wheels. The mid and top models will have a better more efficient heating system.
Here's the Leaf S with it's steel wheels and covers:
This is the new alloy wheels on the mid and upper models:
Old 01-09-2013, 10:06 PM   #7 (permalink)
It's still possible to do a lot of improvements in the Nissan LEAF to improve its overall efficiency.
workaround ideas to discuss among friends: Some considerations about the Nissan LEAF
Old 01-10-2013, 02:08 PM   #8 (permalink)
You're totally correct. Let's hope that the Nissan engineers continue to work on it aggressively. Better aerodynamics could get the range up to ~140 miles.
Old 01-14-2013, 04:52 PM   #9 (permalink)
Nissan has announced the price for the new Leaf S: $28,800.
This should have ripple effects through the EV market - the prices on the Mitsubishi i MiEV and the Chevy Spark EV etc. might now be lower, and Nissan should sell more of the US built 2013 Leaf's.
Old 01-14-2013, 07:11 PM   #10 (permalink)
rmay635703's Avatar
Now how much for the base s with the small battery
