Old 08-11-2015, 09:20 AM   #11 (permalink)
Why did you decide to go with SS?
The Following User Says Thank You to Daox For This Useful Post:
101Volts (12-18-2015)
Old 08-11-2015, 10:29 AM   #12 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Nice work!!!
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
Old 08-11-2015, 07:27 PM   #13 (permalink)
I went with stainless steel for a few reasons.
1 Already had some of it on hand, I bought about 40 feet of used 2 inch 316SS steam pipe for exhaust pipe projects.
2 Stainless is very weldable.
3 The pipe fittings were only marginally more expensive than steel or iron fittings plus bushings I would have needed to make it work from lowes.
4 Getting the pipe fittings off ebay I could get them in the size I need, eliminating the need for bushings.
5 It looks cool.
Old 08-15-2015, 07:50 PM   #14 (permalink)
Here is what it looks like when you try to use 2 inch fittings all around.
I only mocked it up and thought, mmmmm No.
Big, ugly, heavy and all around looks poorly done.
Old 08-20-2015, 10:28 AM   #15 (permalink)
SUVcruiser - '07 Ssangyong Kyron 2.0 XDI
90 day: 42.55 mpg (US)
SUVcruiser year 2017 - '07 Ssangyong Kyron 2.0XDI
Hybridcruiser 2023 - '13 Volvo V60 D6 AWD
90 day: 123.84 mpg (US)
Can you use copper parts to? Or would it corrode to fast?
Drive smart, save fuel, save money, spare the enviroment
But keep having fun!
I can drift
Previous car. SUV. From 2011+ 10l/100km to 2017 5,516l/100km.
2017 without holiday: 5,397l/100km
EPA Rated average: 8,1l/100km
Current ride: plug in 285hp hybrid
EPA Rated average: 2,8l/100km
The Following User Says Thank You to TimV For This Useful Post:
Old 08-20-2015, 04:11 PM   #16 (permalink)
Copper would be fine but the 2 inch fittings needed would be very expensive.
Old 08-20-2015, 04:34 PM   #17 (permalink)
I aint need it any more, just orded a 3 glow plug heater
Originally Posted by TimV View Post
Ok, I orderd the coolant heater, a switch, an 80A relay and a 60A fuse + holder
Total of 88,87€
And this is a good investmend!
I always have a long warm up time, even in summer!
@ 20 degrees Celcius air temps with full upper grill block: 20 minutes (16km) to go from 25 to 85 degrees Celcius coolant temps.
@ -5 degrees Celcius air temps with full upper grill block: 35 minutes (30 km) to go from 0 to 85 degrees Celcius coolant temps
Hopefully those 600W and aditional alternator load would help the warm up times.
I can drift
Old 08-20-2015, 04:52 PM   #18 (permalink)
I am used to glow plugs like that only using about 10 amps each.
Those draw 20 amps each?
Just remember the alternator likely puts out less than 30 amps at lower engine speed. The alternator needs to get spinning upward of 6,000rpm any where near its rated output.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
101Volts (12-18-2015), Daox (08-20-2015)
Old 08-20-2015, 04:56 PM   #19 (permalink)
Also, powering heating up your engine with alternator power really isn't a great way to gain efficiency.
Old 08-20-2015, 05:45 PM   #20 (permalink)
Ive got an (80)150amps alternator. So probably putting out 80 amps at idle.
I just dont have the ability to plug in with an extension cord.
So i aim forces to use this.
I can drift
