Old 04-30-2008, 08:30 AM   #1 (permalink)
Fastening coroplast to the underbody
I ordered the coroplast for the Matrix last night and it should be in sometime today. So, I've been thinking about how I want to fasten it to the body. I don't want to squish it, but I need the bolts to stay in. So, I was thinking about using some bushings. How have you guys fastened coroplast to your body?
Old 04-30-2008, 01:35 PM   #2 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
I'm looking at using push-ins where I need to mount Coroplast and have access to the other side. Some are acorn pushins and some look like a flat piece of metal stamped with a hole that will accept a screw but still keep some tension on it so it won't back out. You could just add a spring on a screw or mount a grommet on the coroplast and hang it with a spring. I'm still exploring ideas too.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
Old 05-23-2008, 02:57 AM   #3 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
You can find or modify finishing washers to provide a flat flange around a countersunk screwhead. If you can't find any, drill and countersink a chunk of scrap, and then pound regular finishing washers.
crx coroplast belly pan finished! paulwelkins EcoModding Central 28 05-15-2015 05:24 AM
Where did you buy Coroplast? tjts1 EcoModding Central 28 11-18-2009 01:12 AM
Coroplast undertray question (covering the control arms) Otto Aerodynamics 8 03-30-2009 12:27 PM
Great find: partial underbody tray for Gen1 IS300 and Gen3 Camry NoCO2 Aerodynamics 3 04-22-2008 01:04 PM
Coroplast question Otto Aerodynamics 14 03-27-2008 11:45 PM
