Old 01-23-2008, 02:09 PM   #11 (permalink)
I just roll the car back a little bit until the valve is at the bottom of the tire. No gymnastics required!
My car is bigger than a Metro and it always seemed the place where the air hose was, was on a slope or something that made rolling the car back and forth a bit of an adventure. My next skirts, if there are any, will hinge or pop off easily.
Old 01-23-2008, 06:54 PM   #12 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Daox -
I've been thinking about how I would fasten wheel skirts on the car should I decide to make some. I've read a few DIYs and none I have seen seem like a great option. Ideally you'd want a tooless design that doesn't take long to remove. This obviously isn't the easiest thing for us DIYers. Here are a few things I was looking into. I'd like to hear from others.
I guess I'm curious how the OEM sideskirts are held to cars? Some sort of plastic snap would probably work great, but I haven't found any good ones readily avaliable.
I like your design because it does look like a "fast disconnect". The guide pins are a great idea. The wing nuts make me think that they will shake off from vibration. Maybe cotter pins or some functional equivalent instead? I think it could be "more flush" to the bottom of the car :
Cotter pin - Wiki
http://en.wikipedia.org/wiki/Cotter_pin
SLIC Pins
http://www.pivotpins.com/catalog/SLIC.shtml
Positive Lock Pins
http://www.pivotpins.com/catalog/PsLckPns.shtml
DETENT PINS
http://www.carrlane.com/Catalog/inde...173C3B28535740
CarloSW2
American Solar Energy Society
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 07:45 AM
Done: A-B-A test on rear wheel skirts - Corolla, Camry Hybrid MetroMPG Aerodynamics 11 06-06-2009 03:49 PM
Geo Metro rear wheel skirts - 2 examples MetroMPG Aerodynamics 10 02-27-2008 10:09 PM
Found a coastdown hill! Mini comparo: windows vs skirts vs hatchback MetroMPG Aerodynamics 4 11-27-2007 11:40 PM
