Old 12-05-2017, 01:21 PM   #401 (permalink)
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
Thanks. I ran a CB Magnaspark (the low end model) on my Superbeetle for two years. At the end of two years, the inside was completely corroded and the Hall effect sensor had snapped in half. CB said "they all do that" (so beware). I forget the details, but it was something like $450 for the unit, $350 for a rebuild that failed and another $100+ for a 009 and Perlux Ignitor. So a close-to-$1000 experiment.
What are the HVX moods
Thanks for the heads up! In some distant future I've actually thought about making my own ignition system with separate spark tables for each cylinder. (Talk about being a perfectionist!)
I would make it run off a Ford TFI module and a Toyota 1.5ohm coil. I've heard these do well for super lean burning in VW engines.
HVX mods are oiling mods designed to get more oil to the heads and thus cool them better:
Bob Hoover's Blog: HVX MODS
Of course with all the work done to this car I really ought to just keep it for my long distance driving.
The Following User Says Thank You to Isaac Zackary For This Useful Post:
freebeard (12-05-2017)
Old 12-05-2017, 04:01 PM   #402 (permalink)
Thanks. You sell that and they will never sufficiently appreciate what they have.
Magnaspark had 3 or 4 levels of tech, from basically a Ford Hall effect sensor in a billet aluminum housing to something that doesn't even have a rotor. Maybe double-check the ventilation in the housing or dismantle it and anodize/paint the housing and reassemble.
You can't be wise and in love at the same time. -- Bob Dylan
Old 12-06-2017, 02:12 PM   #403 (permalink)
I was reading something else and I thought about this.
For a super tune, Motion would install metal core Packard 535 spark plug wires, with Rajah bakelite plug clips
If you don't have a radio the noise-surpressing wires aren't necessary, and the Rajah SS-SOS part would fit the applcation.
Isaac Zackary (12-06-2017)
