EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Finally Did a Grille Block (https://ecomodder.com/forum/showthread.php/finally-did-grille-block-27973.html)
PAFirefighter11 01-13-2014 04:46 PM
Just got around to doing a grille block. I found some black duct tape that is a near match to the OE black on my HX. Not that I care since this car is purely my commuter, and I'm not trying to make a $500 car look good!
Here are the POS cell photos:
http://pafirefighter11.smugmug.com/A...6105482-XL.jpg
http://pafirefighter11.smugmug.com/A...6092178-XL.jpg
I'll grab some better quality shots when free time arises.
California98Civic 01-13-2014 05:55 PM
That'll work, but watch your temps. Yours is even more enclosed than mine, and on long hill climbs my temps rise to the middle and high 190s. In such situations, I will run the heater sometimes to prevent the temp crossing 200. But I think I miht need a new radiator fan or thermostat or something too. Did you duct what air come in the remaining opening into the radiator?
PAFirefighter11 01-13-2014 06:03 PM
I have only 1 hill climb on my trip to work. It's approx. 1 mile and not sure of the grade, but nothing too intense. The same hill on the way back is a shorter hill, around 1/2 a mile.
It's FREEZING here in winter (As low as -2°F so far this season). Summer definitely can hit the upper 90's with high humidity, but I figured as that rolls around I'll have a better setup than this, or can duct it at that point as you said.
Xist 01-13-2014 07:29 PM
https://scontent-a-sjc.xx.fbcdn.net/...10712971_n.jpg
Personally, I prefer mine, although I really need to do A-B-A, I just always feel too busy, and if I ever did the things that I feel that I need to do instead of A-B-A testing, I would feel much better about myself.
Meanwhile, I have new Tetris turns! :D
PAFirefighter11 01-14-2014 12:19 PM
I'm already catching slack from co-workers about it. "You put duct tape on your car?!" Yep... I put duct tape on my $500 car. I'm a bad man lol.
UltArc 01-14-2014 01:13 PM
Get ready for the "your cars gonna blow up!" comments.
California98Civic 01-14-2014 02:23 PM
Tell them you get heat faster, the car saves fuel, and the engine stays warmer longer in between trips. You save a little money (a little) and you're more comfortable. Luxury!
NeilBlanchard 01-15-2014 01:03 PM
Did you block off any openings in the "chin" area, so that all air that goes in the opening, goes through the radiator?
PAFirefighter11 01-20-2014 11:41 PM
Wow. Just an MPG update. FWIW: I use the same pump at the same station every time I fill up. This past tank I got stuck in traffic twice, for a total of 45 minutes of additional stop and go traffic. The tank before I got stuck once in traffic. This is the first full tank with the "aero mods" on the front of the car.
http://pafirefighter11.smugmug.com/A...L/photo-XL.png
UltArc 01-21-2014 12:19 PM
Nice work! Other factors are surely in play, but there is sure to be a difference.
