Old 05-31-2011, 12:17 PM   #1 (permalink)
The Red Bomber - '93 Geo Metro
90 day: 43.53 mpg (US)
My other car - '05 Infiniti G35x x
47.2 MPG, check out my progress!
My fuel log is looking good. Thanks a ton to all the tips and ideas here on ecomodder, it really works!
Here are the things I did that I think made the most improvements to my mileage -
Coasted in neutral whenever possible
Inflated tires to max pressure (35 psi on my 12's) (previous tank was at 27 psi most of the time)
Rarely drove over 60, never over 65
Turned engine off at red lights and EOC in my neighborhood only, about 0.2 miles per day.
Shift to higher gears as soon as possible, kept RPMs low.
Used an iPhone app called GoDriveGreen to tell me how my MPG and "green score" is on each commute. haven't installed the MPGuino yet.
No mods to my car yet.
I really want to hit the 50 mark next - what should I do?
Old 05-31-2011, 12:49 PM   #2 (permalink)
piers.singer's Avatar
Well done on your progress, your numbers are looking good. If you feel confident then you should expand upon your use of EOC, the benefits add up very quickly. You might also like to consider some aero-mods, a grille block might be a good place to start as well as making sure that the front end is smooth, with no depressions sucking in air.
Spoken like a champion. Oh no, disaster!
Old 05-31-2011, 12:53 PM   #3 (permalink)
Perhaps, I'm a bit scared of EOC. My front end isn't that smooth - the bucket headlights could use covering for example. I was thinking of adding a lawn edging strip to the bottom of the bumper to extend it lower. I could use some to block a bit of the grill too. I have un-covered wheels (exposed lugs etc) so getting wheel covers would be a good idea too. It's pretty much a stock Metro.
Old 05-31-2011, 01:09 PM   #4 (permalink)
I hear you, I'm still in the EOC-is-a-bit-scary phase. Covering the headlights with a bit of perspex is a good start, you can also make some wheel covers out of coroplast or pizza pans, be inventive! The lawn edging trick is pretty popular right now so give it a go and let us know how you get on.
Old 05-31-2011, 06:39 PM   #5 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
I'm not going there. Tried it, but probably won't do it.
Check out how often you can apply the brakes before the boost is gone.
(If a Metro has a boosted brake system at all.)
Have a go at the search function, it's been done before by one of the members.
Is this your first stick-shift car ?
BTW - Are you going to name all your tanks ?
Nice improvement though
Old 05-31-2011, 06:43 PM   #6 (permalink)
Nah, but I'm in competition with my carpool buddy, so he drove one tank and I drove the next to see who gets the best mileage. So it's for posterity.
Old 05-31-2011, 06:45 PM   #7 (permalink)
Yes it's my first stick-shift car. Hence my first tank going so poorly. I've got it down now
Old 05-31-2011, 11:31 PM   #8 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Make 55 mph your absolute top speed. That's probably good for 3-5 mpg right there. You get no bragging rights driving a Metro until you can regularly soundly whip a guy driving a boxy Scion xB .
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
