Old 11-02-2018, 11:42 PM   #11 (permalink)
Boltar - '19 Chevy Bolt LT
I haven’t yet. It was a super hot summer so I didn’t even consider it. Today was cooler, 85, but I’m guessing that with how short my commute is overheating isn’t going to be a big deal, will just help my engine warm up faster which is what I want.
I will definitely look into this!
You recommending the upper grill portion, or the lower area where the fog lights are?
Could prob work up a front air dam.
Old 11-03-2018, 01:57 AM   #12 (permalink)
ScanGauge <3
ThermionicScott's Avatar
I think the general consensus is to block the upper grille first. For most cars, that seems to give more of an aerodynamic and warm-up bang for the buck than blocking the lower grille, although I'm not sure if that holds for the Prius.
Big +1 to vskid3's post: rather than overheating, it might be that blocking the grille could allow the system to shift into electric mode sooner. Just keep an eye on the coolant temp.
Best tank (so far): 32 MPG
Old 11-03-2018, 08:16 PM   #13 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
I left the top grill open and blocked the center of the lower grill. If I remember correctly there are 5 rows on the bottom. I left the top and bottom rows open so air could get to all parts of the radiator. I just used strips of black Duct tape and left in on all year. (This was when I lived in Alabama with summer temperatures routinely in the 90’s.)
