Old 11-22-2024, 03:37 PM   #1 (permalink)
$64.60 MAXKGO Controller used to turn alternator into motor with REGEN!
If this controller turns an alternator into a motor with REGEN;
then you could easily turn your cars alternator into a motor/alternator!?
Here's the video with the alternator being fitted to a quad bike that looks to have quite a bit of oomph!
The shown setup is easy via a wireless or wired app.
Here's the MAXKGO MINIV6.8 60V 100A controller and software:
https://maxkgo.com/products/maxkgo-m...ized-heat-sink
mort (11-23-2024)
Old 11-23-2024, 05:48 PM   #2 (permalink)
Nobody?
I want one!
It'll disappear as soon as it hits local customs sadly, unless I use DHL which costs a fortune.
I'm thinking that if one feeds the regen to some supercaps and then a MPPT you should get more regen than otherwise:
Supercaps can take amps and MPPTs change low rpm/voltage into pulses of battery charging specific high voltage pulses.
Just an MPPT would also work.
Then you want rotor field winding control to zero cogging when coasting etc
and to increase the rpms at which the motor can run etc.
Old 11-23-2024, 07:03 PM   #3 (permalink)
Pretty impressive on a 48V lead acid pack:
