Old 06-22-2008, 05:37 PM   #11 (permalink)
Silverfox
mikeb535's Avatar
Focused - '07 Ford Focus SES
90 day: 29.03 mpg (US)
Great looking mods. Is that plexi glass you used to block front grille? I have an 07 SES and wanting to do what you have done. Any mpg increase since modified.
Mike
Old 06-22-2008, 09:19 PM   #12 (permalink)
EcoFocus
EcoFocus - '06 Ford Focus SES
90 day: 27.77 mpg (US)
EcoSienna - '05 Toyota Sienna LE
90 day: 18.77 mpg (US)
Eco Monterey - '04 Mercury Monterey Luxury
90 day: 13.27 mpg (US)
EcoOutback - '98 Subaru Outback
90 day: 18.12 mpg (US)
My grill blocker is lexan. I chose it because it will not yellow. You could make a cheaper acrylic one. You can see on my fuel log that I have a minimum of 1mpg improvement. If I had a scan gage I would do a proper A-B-A.
RabbitM
Old 07-16-2008, 07:44 PM   #13 (permalink)
Sl2 - '99 Saturn SL2 base
90 day: 40.38 mpg (US)
Send a message via AIM to ExMachina Send a message via MSN to ExMachina
Does blocking the grill cause the car to get warmer? I was thinking about doing the same to my 03 focus but was worried that cutting off the airflow may cause it to overheat easier. Does it on yours?
Old 07-16-2008, 10:15 PM   #14 (permalink)
Hello,
The grill block might be more effective if it was flush on the outside?
I drove a ZX5 just prior to my xA. Mine was a 2002 manual. You are doing very well -- I think I got about 28.5 once in a while...
The grill block on my xA (also on the upper grill) had no affect on the temperature. My ScanGage is typically around 184F, on hot days.
Old 07-16-2008, 10:22 PM   #15 (permalink)
6th Gen Coupe - '02 Honda Accord EX 4 cyl
90 day: 28.01 mpg (US)
Zombie Accord - '98 Honda Accord EX
90 day: 24.71 mpg (US)
Ol' Red - '96 Ford F-150 XL
90 day: 14.43 mpg (US)
The grill block looks great! The grill doesn't look that thick, so I'm going to bet that the added benefits of placing it on the outside are pretty marginal. It looks 100x better on the inside. I love the zipties too.. that's how my grill block is fastened
That's quite a stealthy airdam. I might look into getting that for my car also since it has black paint as well. Where did you get it, and what did you use to fasten it to the car?
Old 07-16-2008, 10:44 PM   #16 (permalink)
Hi,
This game is all about margins -- my exterior grill block (still temporary, now with transparent "weatherstripping" tape) gained me 2-3mpg. So not only does the constant fuel use on the highway go down by a greater amount, but also it is possible for me to coast down gentler grades, than I could otherwise.
The grill block (on my xA anyway) is about 2X more effective than my first take on rear wheel skirts. It is the most important part of the car -- since it is first to start to push the air. The pressure there is (probably) the highest, so smaller "flaws" make a greater difference than they would elsewhere.
The Focus' grill is recessed (maybe an 1"?) and the diamond grill itself is maybe ~1/2" deep? The lip that is formed at the top is ~1 1/2" which doesn't sound trivial to me. Some black Coroplast could be fashioned to form a flush surface, so the air flow has no lip at all would likely be much better.
Old 07-16-2008, 10:50 PM   #17 (permalink)
EcoFocus
I have had no engine temp issues with the grill blocker. Problem with the external blocker is how to meet function, easy of manufacturing(lots of exposed curves), look reasonably discrete and not damage the OE grill part( SO I can remove it when I sell the car).
The air dam is made from lawn edging, but it is formed. I may take a second try at it. Actually the only problem is how easy it is to drag on a driveway ramp.
Old 12-28-2011, 02:00 PM   #18 (permalink)
Smash 100 MPG barrier
mbrac's Avatar
Frankie - '07 Ford Focus SEL
can't see pics
I can't see the pictures - can you maybe send me the pictures to my e-mail address? mjkbracht@yahoo.com
I'd really like to see them - can you tell me if you send them - I don't use that account much - it's there for things like this
thanks in advance
The Following User Says Thank You to mbrac For This Useful Post:
ECO-AKJ (05-29-2015)
GM mods the Sierra hybrid pickup: aerodynamic tweaks + LRR MetroMPG EcoModding Central 5 09-03-2012 08:17 AM
Large Pickup Aerodynamic Mods buckyball Aerodynamics 43 08-02-2008 05:49 PM
Getting started with Eco Focus.... RabbitM Introductions 3 06-15-2008 04:13 PM
Hail to the eco nerds! paulwelkins Introductions 5 01-07-2008 09:43 AM
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 07:46 AM
