Old 07-26-2008, 10:40 PM   #1 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Flashing yellow light
Newspaper and mail delivery vehicles have flashing yellow lights on top, which show other drivers that they will likely need to pass to get around the slow moving vehicles which may make unexpected stops.
This type of light might be useful for Engine Off Coasting, to encourage people to pass and to warn of nonstandard driving behavior. For example, I like to coast down to 30mph before restarting and running through 4rth and 5th gear. I would prefer if other drivers passed when they have the opportunity. A flashing yellow light might encourage the timid or overly polite.
When I get some time, I will look through the motor vehicle code and see if and when using a flashing yellow light is permitted.
Anyone else use one of these? Anyone think this is a good/bad idea?
Nissan Versa Aeromods
Old 07-26-2008, 10:43 PM   #2 (permalink)
VIVA LA MPG RESISTANCE
Will's Avatar
Meat-roll - '97 Geo Metro
90 day: 55.4 mpg (US)
Wife's Brruik - '03 Buick Century
90 day: 30.84 mpg (US)
Blue Balt - '08 Chevrolet Cobalt XFE
Team Chevy
90 day: 38.19 mpg (US)
Pretty good idea, but I like a sign... You know, like this one
Old 07-27-2008, 08:40 AM   #3 (permalink)
skyl4rk's Avatar
It looks like it is probably not legal to use a flashing yellow light in MI unless you fall under some type of emergency or service vehicle status.
MCL 257.698
(5) The use or possession of flashing, oscillating, or rotating lights of any color is prohibited except as otherwise provided by law, or under the following circumstances:
(a) A police vehicle shall be equipped with flashing, rotating, or oscillating red or blue lights, for use in the performance of police duties.
(b) A fire vehicle or ambulance available for public use or for use of the United States, the state, or any unit of the state, whether publicly or privately owned, shall be equipped with flashing, rotating, or oscillating red lights and used as required for safety.
(c) An authorized emergency vehicle as defined in section 2 may be equipped with flashing, rotating, or oscillating red lights for use when responding to an emergency call if when in use the flashing, rotating, or oscillating red lights are mounted on the roof section of the vehicle, either as a permanent installation or by means of suction cups or magnets and are clearly visible in a 360 degree arc from a distance of 500 feet when in use. A person operating lights under this subdivision at any time other than when responding to an emergency call is guilty of a misdemeanor.
(d) Flashing, rotating, or oscillating amber lights, placed in a position as to be visible throughout an arc of 360 degrees, shall be used by a state, county, or municipal vehicle engaged in the removal of ice, snow, or other material from the highway and in other operations designed to control ice and snow.
(e) A vehicle used for the cleanup of spills or a necessary emergency response action taken pursuant to state or federal law or a vehicle operated by an employee of the department of natural resources that responds to a spill, emergency response action, complaint, or compliance activity may be equipped with flashing, rotating, or oscillating amber lights. Such lights shall not be activated unless the vehicle is at the scene of a spill, emergency response action, complaint, or compliance activity.
(f) A vehicle to perform public utility service, a vehicle owned or leased by and licensed as a business for use in the collection and hauling of refuse, an automobile service car or wrecker, a vehicle engaged in authorized highway repair or maintenance, a vehicle of a peace officer, a vehicle operated by a rural letter carrier or a person under contract to deliver newspapers or other publications by motor route, a vehicle utilized for snow removal, a private security guard vehicle as authorized in subsection (7), a motor vehicle while engaged in escorting or transporting an oversize load that has been issued a permit by the state transportation department or a local authority with respect to highways under its jurisdiction, a vehicle owned by the national guard or a United States military vehicle while traveling under the appropriate recognized military authority, a motor vehicle while towing an implement of husbandry, or an implement of husbandry may be equipped with flashing, rotating, or oscillating amber lights. However, a wrecker may be equipped with flashing, rotating, or oscillating red lights which shall be activated only when the wrecker is engaged in removing or assisting a vehicle at the scene of a traffic accident or disablement. The flashing, rotating, or oscillating amber lights shall not be activated except in those circumstances that the warning produced by the lights is required for public safety.
(g) A vehicle engaged in leading or escorting a funeral procession or any vehicle that is part of a funeral procession may be equipped with flashing, rotating, or oscillating purple or amber lights which shall not be activated except during a funeral procession.
(h) An authorized emergency vehicle may display flashing, rotating, or oscillating white lights in conjunction with an authorized emergency light as prescribed in this section.
(i) A private motor vehicle of a physician responding to an emergency call may be equipped with and the physician may use flashing, rotating, or oscillating red lights mounted on the roof section of the vehicle either as a permanent installation or by means of magnets or suction cups and clearly visible in a 360 degree arc from a distance of 500 feet when in use. The physician shall first obtain written authorization from the county sheriff.
(j) A public transit vehicle may be equipped with a flashing, oscillating, or rotating light mounted on the roof of the vehicle approximately 6 feet from the rear of the vehicle which displays a white light to the front, side, and rear of the vehicle, which light may be actuated by the driver for use only in inclement weather such as fog, rain, or snow, when boarding or discharging passengers, from 1/2 hour before sunset until 1/2 hour after sunrise, or where conditions hinder the visibility of the public transit vehicle. As used in this subdivision, “public transit vehicle” means a motor vehicle, other than a station wagon or passenger van, with a gross vehicle weight rating of more than 10,000 pounds.
(k) A person engaged in the manufacture, sale, or repair of flashing, rotating, or oscillating lights governed by this subsection may possess the lights for the purpose of employment, but shall not activate the lights upon the highway unless authorized to do so under subsection (6).
Old 07-27-2008, 12:13 PM   #4 (permalink)
Wicked Wanda - '99 VW Beetle GLS
90 day: 29.59 mpg (US)
Green Monster - '99 Ford Explorer Sport
90 day: 16.73 mpg (US)
Dad's Taxi - '99 Honda Odyssey EX
90 day: 24.23 mpg (US)
Personally, I don't think EOC and P&G should be done with other cars around. The vast majority of people on the road would have no idea what you are doing and wouldn't care. They only know you are in their way. It's things like this that cause people on other non-eco websites to view us as anal retentive a$$holes who only care about saving an once of gas vs inconveniencing others who don't share our views.
Old 08-01-2010, 01:21 PM   #5 (permalink)
Fhqwhgads
TheMarkofPolo's Avatar
Vibe o' the Ozarks - '07 Pontiac Vibe
90 day: 31.22 mpg (US)
It might also send a red flag to law enforcement that might or might not see it as a safety hazard when you're driving in neutral with the engine off.
Mennonites in Missouri usually use reflective red triangles when they enter traffic via horse-drawn carriage. Thought about using one of those? (the red triangle, not the carriage)
When we try to pick out anything by itself, we find it hitched to everything else in the universe. John Muir
"Price is what the person pays. Cost is what society pays, here, now, elsewhere and into the future." Natural Capitalism
Old 08-01-2010, 01:57 PM   #6 (permalink)
Hypermiling rookie
Laurentiu's Avatar
Opel Corsa B - '96 Opel Corsa 1.2 8V
90 day: 47.27 mpg (US)
VW Bora 1.6 16V - '02 Volkswagen Bora/Jetta
90 day: 35.84 mpg (US)
A (very) large sticker should do it....Go around followed by a BIG arrow for those that get confused
"It has been my observation that most people get ahead during the time that others waste" Henry Ford
Idea for government: Traffic Light Timers newtonsfirstlaw General Efficiency Discussion 29 03-10-2012 11:33 AM
Technique quandary: gliding toward a stale green light - to pulse or not to pulse? MetroMPG Hypermiling / EcoDriver's Ed 27 04-15-2010 12:41 AM
LED Refridgerator light bennelson Saving@Home 19 01-05-2010 12:06 AM
"Service engine soon" light on rick390 Off-Topic Tech 23 07-26-2008 11:01 PM
