Old 06-07-2012, 11:13 AM   #11 (permalink)
Beyond TLC - '89 Volkswagen Golf Syncro Gti
90 day: 26.78 mpg (US)
Gypsy deathtrap - '96 Seat Cordoba Tdi
90 day: 63.56 mpg (US)
Pinky - '00 Opel Corsa
90 day: 39.29 mpg (US)
corsavan - '11 opel corsavan
90 day: 52.41 mpg (US)
cordoba - '01 seat cordoba estate
90 day: 39 mpg (US)
My old (1989) VW has an after-run temperature sensor mounted near the inlet - if it detects high temps after shut-down (105C iirc), it triggers the radiator fan to draw fresh air into the engine bay, and cool the rad at the same time. Quite a simple system and easy to retro-fit. Controlled by a relay with a timer in it, and runs for a max of 10mins to avoid draining the battery. Thermosiphon effect will circulate the coolant to an extent. Could be worth a try?
Old 06-07-2012, 01:01 PM   #12 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
My HCH1 turns on the cooling fan when the engine is shut off for times between 1 minute and 5 minutes whenever it's particularly warm (I see IAT at maybe 50+C).
So there is some prior art on this.
Sam
