Forget the hydrogen economy, go methanol!
"Scientists in Germany and Italy have discovered a way to derive hydrogen gas from methanol at low temperatures and pressures using soluble ruthenium based ‘pincer’ catalysts."
http://www.rsc.org/chemistryworld/si...nation_630.jpg Supercharging methanol for fuel cells This seems a much better idea as it's sticking with a liquid fuel. One that can initially be made from natural-gas prior to more renewable sources coming on-stream. |
...bet the "...soluble ruthenium based ‘pincer’ catalysts." ain't cheap?!?
Liquid fuels beat all gaseous fuels hands down, but natural gas production is currently consuming fresh water at an unsustainable rate, and causing way more pollution than we know or can handle. Methanol is good stuff, especially for biodiesel production, bet we need to make it from something else, like cellulose. |
My diesel is methanol ready.
Heck any diesel could use methanol to reduce diesel consumption for maybe $1000 right now. Methanol is so much easier to make than ethanol. |
- The thing I like the look of for this methanol tech is the infrastructure adjustments appear to be far easier, whilst issues like range anxiety and 'charging time' are sidestepped. The methanol should not be produced from any fossil source ideally, that's a given. But realistically we need a way to give momentum to newer to technologies (momentum that hydrogen will never gain IMO [and for good reasons]), but personally I'd rather water that we can't be spared (in an ideal world) was used for turning a relatively low carbon fuel like NatGas into an efficient, workable road fuel than have fresh water [and NatGas!] consumed in, say, upgrading tar-sands; continuing business-as-usual! |
To be fair, the future of energy is going to need to be much more diverse than the 20th century was, but unless a diesel or petrol replacement can be made today by means that won't be in competition with someone's arable land (like a way that the whole of the Sahara can be pumping out oil from captured sunlight) I don't see how we aren't going to require some fossil-fuels to make the transition - and natural gas is better than the others! |
That's the 'well' part of the equation; what about the 'wheel'? - nice clean methanol (of what ever source) sloshing around in a fuel tank has the potential (via the tech above) to turn (I'd estimate) three-quarters of it's chemical energy into driving (via a fuel-cell/e-motor) the wheels -full cycle- ... biodiesel is only suited for an ICE and will be lucky to return one quarter chemical efficiency full-cycle; plus it does nothing to encourage wider changes in infrastructure, etc. |
