11-08-2021, 02:01 AM
Fossil Free Tires
Goodyear to phase out petroleum-based tires with soybeans by 2040 Bryce Buyakie, The Daily Record 5/15/2021
https://msn.com/en-us/foodanddrink/foodnews/goodyear-to-phase-out-petroleum-based-tires-with-soybeans-by-2040
Recent studies from the last decade have shown that petroleum isn't as efficient as some once thought. Now, companies, engineers and scientists aim to replace it with plant-based oils, specifically soybeans.
The Goodyear Tire & Rubber Co. recently announced its goal to replace all petroleum-based products with soybean oil by 2040.
The Akron-based firm is one in a line of companies that have begun to partially or fully replace petroleum with plant oil.
Switching to soybeans
Goodyear's search for a petroleum replacement began a decade ago when petroleum prices rose too high, so engineers like Bob Woloszynek sought out cheaper and more sustainable alternatives.
Around the same time, consumer requests started trickling in. They wanted environmentally friendly tires, said Woloszynek, chief engineer in Goodyear's Global Raw Material Development & Approvals department.
"We started to evaluate soybean oil, and being a triglyceride, it has a different chemical structure than your typical petroleum-based oils," he said.
Upon reviewing their initial findings, a few things stood out.
Soybean oil mixed better with the polymers used to create their rubber compounds, making it "a very flexible option," Woloszynek said.
It also has a low glass transition temperature, meaning it freezes at very low conditions.
"If you think of a high-performance summer tire, it's not really suitable for winter conditions because the rubber compound is formulated so that it grips the road in dry conditions and warm conditions," he said. "When it gets cold, that compound has a higher glass transition temperature, so then, as the temperature of the air gets cold, that rubber starts to get stiffer."
The stiffer the tire, the less traction it gets in cold and wet weather.
Soybean oil might allow Woloszynek and other engineers to design tires that could safely operate in hot and cold conditions.
Other investments have gone toward infrastructure projects.
"Basically that is going to help protect bridge decks and things that have a lot of use and maybe a lot of salt or some sort of irritant that they use to help maintain the life of those bridges or roads," Reinhard said.
How many gallons of gasoline in a set of tires? Not much but it's the thought that counts. And removing the oils makes soybeans more valuable as an animal feed.
.tragectory: Line goes down and to the right.
11-08-2021, 02:28 AM
If we used oil for tires, lube, asphalt would go just about indefinitely.
11-08-2021, 02:43 AM
I've heard soybeans are planted by hippies who run on soybeans.
Perhaps if better tires are made with soybean oil which has little other value, that's a win. Seems unlikely, just as I am pessimistic about most "good news".
11-08-2021, 05:19 AM
Yokohama uses orange oil from orange peels. Pretty low food value there.
11-08-2021, 11:59 AM
Just to clarify, I'm not long term pessimistic as technology and efficiency improve over time, but I'm pessimistic about any new thing, since most new ideas are terrible.
11-08-2021, 12:59 PM
Too many cars
What will burnouts smell like?
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
11-08-2021, 01:07 PM
I know I'm weird, but I enjoy the smell of the tire store. Somehow it makes me happy.
11-08-2021, 04:36 PM
#9 (permalink)
Not as good as coconut 🥥 or peanut 🥜 I would guess...
Donald J Trump 8/21/21
Disclaimer...
But...
I play one on the internet.
11-08-2021, 07:19 PM
#10 (permalink)
Much better to use soybean oil for petrochemical specialties and soybean meal as cattle food than roughly giving it away to China.
Had the stereotypical soy-boys been in charge of growing their own soybeans, most likely they would starve to death.
