Old 10-20-2009, 01:00 PM   #1 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
found a good pic of a nice FOR-ECOMODDERS radiator duct
It would be easy to build one and I don't think it absolutely has to have rounded sides. The rounded sides just help the air expand more smoothly and help the air build pressure so it doesn't just blow through one spot on rad. If I can get a hold of some coroplast, I will try it. I know it will help a lot in my case because most of the air goes around the radiator anyway. I did manage to get some small-holed hardware cloth over my grille opening to keep rocks and bugs out. They were doing a number on my radiator after my condenser removal.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 10-20-2009, 01:20 PM   #2 (permalink)
Nice picture Isaac.
The Toyota Prius already does this as I posted a while back in my Prius build thread. I also did some filling in on the Paseo as well to try to improve airflow through the grill, but to a much lesser degree than the Prius has on it.
I'd definitely say it could be used to make the grill opening smaller which would further reduce drag without compromising your cooling ability.
Old 10-20-2009, 01:31 PM   #3 (permalink)
Team Pontiac
I think I could block another 50% of my grille if i put it in
very little air that enters the grille actually goes through the rad. It is completely open around the rad!!!! anybody else have this issue?
It is almost as if the radiator was an after-thought
1991 F-250:
Old 10-20-2009, 04:25 PM   #4 (permalink)
Daq Civic - '92 Honda Civic DX sedan
90 day: 42.54 mpg (US)
The Hardbody - '91 Nissan D21 (pickup)
I've actually done this with coroplast on my car, in conjunction with a grill block and undertray, and even in the summer in stop-and-go traffic temps never got that high--not even tripping the fan for longer than 15 secs at a time. Of course, aero doesn't matter in such conditions, but it illustrates the basic effectiveness of the design. I would venture to guess that I can now make the grill opening 2/3 the size of what it would otherwise have to be.
The Following User Says Thank You to daqcivic For This Useful Post:
IsaacCarlson (10-20-2009)
Found an ignition kill fuse... is it good? RobertSmalls EcoModding Central 0 03-18-2009 05:45 PM
A good way to burn yourself ( I found one) bbjsw10 The Lounge 16 10-08-2008 06:11 PM
