Old 07-11-2008, 09:07 PM   #1 (permalink)
Lurking Around
Impulse's Avatar
96 Civic - '96 Honda Civic CX
90 day: 33.2 mpg (US)
09 Sierra - '09 GMC Sierra SLE
90 day: 19.76 mpg (US)
09 Matrix - '09 Toyota Matrix XR
90 day: 25.22 mpg (US)
96-00 Civic Upper Grill Block
Well I finally had time after work to work on the Civic, so I made a quick and easy upper grill block as seen here (Aftermarket Grill, costs about $20)
I found some chloroplast scraps we had laying around the shop, which is about 1/4 inch thick and is somewhat bendable to an extent
Next I used an exacto knife to cut the rough dimension of th insert out
Then I took a pencil and marked the inside mouth of the grill onto the chloroplast, and cut around the penil marks about 1/4 inch all the way around
Next I screwed the chloroplast from the back side into the grill, there are already screw mounting holes molded in the aftermarket grill that I got
Finshed result.
Fitted to the car. Take note that I had to take out the screws along the top of the grill that held on the chloroplast because the grill would not fit using the screws that I chose, so it is pressure fit in between the grill and the rad support, probably more solid than the screws.
Now to get some ecomiling in!!
Old 07-11-2008, 09:18 PM   #2 (permalink)
90 day: 51.82 mpg (US)
Clean installation. Nice work.
Old 07-12-2008, 03:09 PM   #3 (permalink)
grill block
Stealthy! No one will even know its there.Much nicer than my work.Good job.
OEM Grill Block for 92-95 Civic Owners TomO EcoModding Central 6 12-21-2014 09:58 PM
Civic Block Heater Install TomO DIY / How-to 42 04-04-2012 08:24 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 05:16 PM
2005 Civic Upper Grill Block Harpo Aerodynamics 13 03-17-2008 11:55 AM
