Front bumper shape
Time has come to redo my front bumper. Which is better for aerodynamics, a wedge shape or a rounded over shape?
I'm glad I noticed the "NEXT" button in that link, some interesting stuff.
Sort of on-topic adjacent, check out this rounded sail boat bow. Radical new mini - Boat Design Forums EDIT: I like these book scans, nice info. http://ecomodder.com/forum/member-ae...strations.html |
How can I navigate to this section of the site? Obviously, from the link notation, it is some ref material that Phil put onto the site, but I don't see a way to navigate to the material.
http://ecomodder.com/forum/member-ae...enetration.jpg
http://ecomodder.com/forum/member-ae...oncept-car.jpg http://farm6.static.flickr.com/5121/...17eda205_z.jpg Looks like it's a balancing act between drag reduction (top) and downforce (bottom). With a street car downforce shouldn't be a problem. |
If you want inspiration for a front end, look at modern current model cars. They seem to be an air dam type thing low, below midheight. The air dam tends to remain flatter out to the sides so it "pushes" the air out away from the messiness that is the front wheels. Above midpoint, it is all rounded radius to start the air on its trip over the top.
Like This. http://i40.tinypic.com/vnpkz5.jpg or This http://i39.tinypic.com/k2mrkx.jpg I wonder what the CD penalty is for the hood ornament??? |
That is a lot of help. Thanks. I have been looking at cars coming out now though, and what is with the flat front look. It just appears that having a tall flat bumper would actually cause a negative effect. Does anyone have data on how this effects aerodynamics?
The alternative is a sloping bumper and front end, which doesn't look as good. Bulldog noses are in fashion.
A bullet shape funnels air under the car which creates front end lift. |
Front end lift is something I have been trying to avoid. I do the bulk of my driving at 60 plus and don't want to have issues sticking to the road. I am trying to bat around a lot of ideas, and reviewing stuff that people have already done to find out what works best. I don't like to do, then redo, then do again.
This is what I did and it paid off with almost 15% increase in FE.
http://ecomodder.com/forum/showthrea...job-17534.html |
http://www.motivationalz.com/picture...ical_hippo.jpg |
Here is an example of the attached flow on the bumper of my car during a tuft test. http://farm3.static.flickr.com/2321/...d68dd217_o.jpg |
The problem with the silver bullet nose is that it directs so much air down below the car. |
Here is a site that has lots of useful information ( be sure to click the links to the other pages ! ) regarding blunt, versus wedge, versus bullet shaped noses. Lots of good info such as lift and drag coefficients etc. They even tried testing windshield shapes as well. Winged Warriors/National B-Body Owners Association - Chrysler Winged Car Development and Testing |
Thanks for the input. I am thinking about putting the front end on hold until I get the hubcaps and wheel skirts finished. I am doing the mirror relocation today, so I will see how I like that. I am not trying to go extreme, but 50+ to the gallon would help my finances out a lot.
:thumbup: BTW, how does one go about making a strong stable, durable bullet nose? Perhaps I'll have to study the Aero Civic thread. :turtle: |
I do know the answer to that. Styrofoam and fiberglass mat. Some people don't like to work with it, but it is relatively easy and very durable. You could also use a base layer of household screen and then fiberglass over it. It makes the fiberglass more durable.
I assumed that by " bullet nose " we were talking a half bullet nose, such as a Corvette, a Firebird, a Saturn SC coupe, or the car on page one. http://ecomodder.com/forum/member-ae...oncept-car.jpg Cars with bullet noses such as the Avion will of course have more of the air flowing under the car. http://images.gizmag.com/hero/avion-1.jpg |
There's a bit missing off the front of the Coupe, and yet this is the one (of 5 Tempos) that gets the best fe. I conclude the flow hasn't been compromised all that much, if at all. |
George I just saw the thing about the yachts-really interesting!
And for whatever reason this quote seemed important: Quote:
http://bringatrailer.com/wp-content/...le_Front_1.jpg Quote:
No sarcasm, and that is the 35mpg Tempo (gaslog not on EM).
Maybe the radiator block is so good it more than cancels out the bad headlight areas/fender scoops? |
all that much
Hood edge and bumper radii look plenty smooth. Makes sense to me Frank! |
It is all good but the open areas around the headlights are not closed off; they lead to the inner fenders and after a labyrinth path, the engine compartment. Perhaps what I have is about the same flow through the engine compartment even with that nice big radiator block; or maybe the flow through all that nonsense is stifled such that there isn't really much flow entering those areas in the first place. At any rate, fe and probably top speed (not accurately tested) seem to not be negatively affected.
It would certainly be interesting to see a tuft test along the sides of those fenders Frank.
Thanks for posting the example. I can certainly see what Aerohead was referring to about immediate reattachment along the sides. As far as the little tabs that hold the side signal lights on, they might even function the same way that the creased sides do on the front end of the Prius. Its hard to tell without tufting it though. ( I hope you do get around to fixing that front end ! Good luck passing inspection without the turn signal lights ) |
Here is my 'dead horse' that I keep bringing up from time to time.
This is proof that you can have a blunt 'barn door' front end and still have good aero. This old '80 Camaro got down to a wind tunnel tested .201 Cd - or just over what the EV-1 achieved. Chevy Camaro Aerodynamics Side View Photo 7 http://image.hotrod.com/f/10214169/1...+side_view.jpg Also look at the attached flow with the 'barn door' flat front end on this '32 Coupe : http://www.youtube.com/watch?v=z7Trx...eature=related Notice the flow along the roofline as the smoke stream hits the vertical windshield. http://www.youtube.com/watch?v=mqi6w...eature=related |
Here is another '32 coupe - this one quite draggy by the looks of the smokestream.
Still, this video gives a good idea of how that a simple rounded edge can keep attached flow - for example along the roofline. http://www.youtube.com/watch?v=8PoIo...eature=related |
.201 even with that massive scoop??
There are no inspections. There are turn signal lights. |
Read more: Chevy Camaro Aerodynamics Hoodscoop Photo 5 |
Frank, your Tempo pic reminds me of the truck grille I have not finished yet.
I get to make a scratch bumper for the truck, and I've been watching this thread. Thanks for all the good info. It looks like I need to build something resembling Jay Leno's chin, yet tasteful. Seems like a tall order to me :D |
While this is for the nose of a streamliner; it is still quite interesting.
http://www.aussieinvader.com/wp-cont..._design_dm.pdf |
Anyway. Reducing drag is the goal. Air will most likely prefer a nice, rounded front to a block front. And keep in mind that when you compare it to the EV1, you compare it to a stock car without the giant air dam or gap taping. That's not to say a car with a flat front can't yield good numbers- the Camaro disproves that- but a smooth transition is preferable. Carry on! :) |
People continue to fixate on the front when the top of the windshield on back is where it's at.
Looks like you have a choice of safe and slow, or fast and air-born. |
