Old 03-26-2012, 08:51 PM   #1 (permalink)
Fuel Cutoff Question Scangauge E for a 2000 Mazda
I have a Scangauge E and when off the pedal or coasting my unit will say 9999 . Now I have it at default 24 which apparently the number my car needs. Further reading say 4 above no throttle TPS.
Is there a screen in the Scangauge E that says TPS ? And if so how do I access it?
Or do most just set the cutoff to 0 to disable?
Old 03-27-2012, 12:13 AM   #2 (permalink)
A.J.'s Avatar
The Countess - '03 Mazda Protege LX 2.0
90 day: 25.66 mpg (US)
On the Scangauge E, there are three screens on which you can customize the gauges by pressing the buttons on the right, next to the gauges. Keep pressing until you see TPS. To cycle between the screens, use the buttons on the left.
Refer to the user manual, it has an easy to understand picture which explains the screens and the custom gauges. Good luck.
Btw, what Mazda do you have?
Old 03-27-2012, 07:51 AM   #3 (permalink)
I have a 2000 Mazda 626 4cyc automatic
Also when am I supposed to read the TPS number to base my cutoff with? Should I be driving?
Old 03-27-2012, 11:51 AM   #4 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
You want to set your cutoff value to be 4 above idle TPS.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 03-28-2012, 11:18 PM   #5 (permalink)
Thanks I will try it tommorow
