Old 01-02-2012, 02:56 PM   #1 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
blending different oil grades?
So the iS is overdue an oil change...
The book oil for the car is 10w40 semi synth-local supermarket had some castrol going cheap,so I now have enough 10w40 for 3 changes I may purchase more..
Question is this-could I 'blend' in some 5w30 to make it a bit thinner?
Just thinking it may be better being thinner in the cold weather we have..
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 01-02-2012, 03:02 PM   #2 (permalink)
...beats walking...
...yes, you can "do it," but, no, it won't make the oil 'thinner' overall.
Old 01-02-2012, 03:20 PM   #3 (permalink)
Team m8
Thanks,exactly the answer I was looking for...
Guess i'll just plough more cash into the 10w40 as its 1/2price
Old 01-02-2012, 10:58 PM   #4 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
bad idea - see BITOG foums
using 10w40IF AND I REPEAT IF it is approved by BMW for your application is the way to go
but
more important than the viscosity values are the BMW oil specifications which are applicable for that car/engine .
BMW LL01 afaik
so a off the shelf 10w40 semi synthetic is NOT acceptable and
there are many if not all oils that meet BMW LL01 that are not 10w40
ALL OF THEM ARE FULL SYNTHETIC and meet the
ACEA A3 B3 - A3 B4 specification as well as the BMW LL01 specification
i would contact BMW direct
OR
look in the BITOG forum in the European section to clarify exactly what the minimum oil specification for your car really is and never use an oil that does not meet that specification .
and
mortals who are not lubrication engineers should never "blend oils"
unless they are salad oils for salads only
unless
unless you enjoy pain and internal engine work on older BMW engines
The Following User Says Thank You to mwebb For This Useful Post:
Piwoslaw (01-03-2012)
Old 01-03-2012, 05:02 AM   #5 (permalink)
Team m8
Originally Posted by mwebb View Post
using 10w40IF AND I REPEAT IFit is approved by BMW for your application is the way to go
but
BMW LL01 afaik
OR
The oil meets the relevant standards as required by the owners manual.
and
unless
Old Tele man's response indicated that already,so i honestly don't see what your response adds to this thread.thanks for dropping by, in your whacky blue way,but I feel I've got the answer i needed after one post.
Old 01-03-2012, 06:06 AM   #6 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
If you want thinner for cold weather 5w-40 is what you should look for.
Motor Oil Viscosity Grades Explained in Layman's Terms
We have full synth 5w-40 API SM/CF, ACEA A3/B3/B4 for £5.60/L here.
The Following User Says Thank You to jakobnev For This Useful Post:
320touring (01-03-2012)
Old 01-03-2012, 06:08 AM   #7 (permalink)
Team m8
Thanks for the recommendation!
Will see what I can find over here
Old 01-04-2012, 12:06 AM   #8 (permalink)
mwebb's Avatar
BMW specifications
the oils referred to in the owners manual
no longer exist
which is a good thing
the BMW specifications have been upgraded to reflect current lubricants
spend a wee bit of time in the BITOG forum
study and learn
it does not hurt
your engines will thank you
