EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Fuel economy in the air (diesel airplanes?) (https://ecomodder.com/forum/showthread.php/fuel-economy-air-diesel-airplanes-11486.html)
The Atomic Ass 12-17-2009 03:29 PM
So I was reading the thread I can no longer find a while ago, and the thought has been roiling around in my mind since... Most prop planes are spark-ignition, aren't they?
Has anyone ever built a diesel prop plane?
Christ 12-17-2009 03:40 PM
Good question. I'm intrigued. (Actually, I'm Christ. Intrigued is another member.) Nonetheless, I'm interested to see what kind of information gets dragged up in this thread.
gone-ot 12-17-2009 04:17 PM
...yes, diesel engines were used a lot during the 1920's-1930's:
http://74.125.155.132/search?q=cache...&ct=clnk&gl=us
...on a similar note -- I'd like to know "why?" EPA-fuel economy "guidelines" haven't also been applied (shoved up?) to the aircraft industry yet?
shovel 12-17-2009 04:20 PM
i have to imagine diesels are somewhat differently affected by altitude since their compression ratio is much more critical to combustion
The Atomic Ass 12-17-2009 08:08 PM
What better excuse can there be to put a turbo on an engine. Although I was thinking in terms of a <10,000ft. type of plane.
Mustang Dave 12-17-2009 09:39 PM
The German Junkers bombers of WWII were diesel-powered.
Christ 12-17-2009 09:42 PM
That's why they make chokes.
Design the engine to run efficiently at high alt, and at low alt, it'll probably blow up, so you either set it up to only use a max amount of fuel, which is pig-rich at low alt, and perfect at high alt, or you set it up with a choke, so that it runs as a smaller displacement engine (effective displacement) at low alt, and runs "normally" at high alt.
gone-ot 12-17-2009 09:44 PM
...uh, guys, two words: turbocharger and wastegate
...turbo's were usually used on ALL high-altitude engines, especially fighters.
Frank Lee 12-17-2009 09:59 PM
IIRC the main concern is fuel gelling and emergency air restarts, they see some real cold conditions.
dcb 12-17-2009 10:41 PM
theres a couple hits for diesel airplane on youtube
http://www.youtube.com/watch?v=l0BhcIT2V1s
(mentions Vulcan Diesel at 3:50 )
http://www.youtube.com/watch?v=Y-ybGay_-t8
