Old 10-12-2012, 04:21 PM   #21 (permalink)
The PRC.
Another vote for the 1.9 TDI - it has all the advantages -
- Can run on veggie oil
- Available, find a scrappie TDI, and if it breaks there is another one available
- Conversion kits for N/S installation are easy
- Tuneable, up to 180hp/300+ lb/ft if you like being able to stuff 'vettes without trying.
The 5 cyl Merc is good if you like a "plugger" type engine - enough torque to keep going forever but nothing much more. Its kind of a European truck engine fitted to a car.
The Following User Says Thank You to Arragonis For This Useful Post:
Christ (10-12-2012)
Old 10-12-2012, 05:34 PM   #22 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
Originally Posted by pete c View Post
I also own a 3 liter V-6 ranger. The vulcan V-6 is a very good reliable motor, but, they don't call it the 3.slow for nothin'.
Haha 3. slow
It was a thirsty truck as well, I never tried to get good mileage in that truck, 20-21 mpg was the numbers i was seeing with it. Sold it, bought my Beetle and enjoy 3 times the mileage.
For every $50 i put in the Beetles tank i would have had to put $150 into the Rangers tank.
I have a hitch & trailer for the beetle so it does everything i need it too.
Save gas
Old 10-12-2012, 07:14 PM   #23 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
The benz I5 turbo version is the way to go. Plenty of power and they will outlast that S-10 a few times over. BTW, I am talking of the old (85-earlier) OM-617. It is cast iron, top to bottom and will go a million miles if maintained at all. The newer benzes are partly aluminum and don't have anything close to the same reliability/longevity.
Can you say heavy? The turbo is the only choice to get any torque at all out of the cast iron Benz engine.
I'm not coasting, I'm shifting slowly.
Old 10-12-2012, 09:00 PM   #24 (permalink)
Originally Posted by bennelson View Post
Turbos are nice, but I can never seems to find anything affordable with a turbo on the used market.
You could buy a turbo and make it fit.
I was able to find my holset HE351VE turbocharger on cregslist for $180.
You could buy a working used IDI diesel cheap and a working used small turbo charger for dirt cheap and make them work together.
Old 10-12-2012, 09:15 PM   #25 (permalink)
My S10 is a 1995, so it is pre-ODBII.
I think it's all less of an issue because of that.
Not being OBD-compliant is a good point, since it solves all the issues in that matter. You can use any engine, either all-mechanical or electronically-controlled. Would worth to take a look at a Mercedes 240D (yes, the 4-banger one).
If its 4cyl OM616 can move the van below (Spanish-made Mercedes-Benz MB180-D, with an upgraded 79-ish hp version of the engine and a FWD transaxle), wouldn't be a bad option for an S10.
Diesel- and Hybrid-Powered Vehicles Can Provide More Societal Benefits than Gas-Power SVOboy General Efficiency Discussion 12 04-29-2017 08:03 AM
VW TDI vs. Gas comparison guudasitgets General Efficiency Discussion 99 11-27-2009 08:12 PM
My introduction to hypermiling the Smart Ptero Hypermiling / EcoDriver's Ed 12 10-28-2008 07:32 PM
DIY decel fuel cutoff; alternator regulation; auto start/stop MetroMPG EcoModding Central 0 11-29-2007 02:04 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
